Rosemary Ainslie Quantum Magazine Circuit COP > 17 Claims
Started by TinselKoala, August 24, 2013, 02:20:03 AM
Quote from: Tseak on April 07, 2014, 07:23:11 AM
TK,
Just out of curiosity, did you ever figure out what those kinks are at the bottom of your temperature curves ~3 minutes into the measurement?
I think that's when the oil in the cell starts to convect fully. I suppose I could put some dye layers in there, watch it closely with the video camera and correlate the kink with the visible disturbance in the dye layers due to the convecting oil.
For more precision, one would constantly stir the oil with an actual magnetic stirrer plate thing, but I don't have one and didn't see any at the last garage sales I attended. I suppose I could kludge one up, using the Arduino, some old TV parts and the motor from my RC helicopter. When I need to show the difference between COP = 1 and COP = 1.02, I'll have to do that.
Right now I'm really wishing I had a good 100x attenuated oscilloscope probe. I wonder if there are any garage sales this week.... I could probably make one out of a used curling iron and an old Nintendo controller.
I've just finished building and testing the MarkE Gate Current Booster circuit. It works a treat!
I had to dig around in my spares pile to find a suitable PNP transistor though, because I didn't have what I thought I had in stock. I wound up using 2n2219a (NPN) and RCA 40319 (PNP), a nicely matched complimentary pair. I also put in a 10uF tantalum cap on the +v supply side, just because.
It eliminates the need for a negative offset to get a clean turn off and allows better mosfet performance (less time in linear conductance region). It allows more adjustment on the positive voltage side. If I go too far ... it also allows so much "oscillation" or ringing that I can make all the meters go craaaazy man, real craaazy, even the ones in my Topward psu. I'm not going to post any screenshots right now, I'm still playing around, but at some point I'll show a comparison with and without the MarkE Gate Current Booster.
MarkE
Quote from: TinselKoala on April 07, 2014, 10:46:27 AM
When you  use the booster, you might want to consider a TVS device rated at 600V or so to protect the MOSFET drain.
Pirate88179
Quote from: MarkE on April 06, 2014, 09:55:20 AM
How can you afford such sophisticated test gear?
Mark:
Well, as I am sure you are aware, even the most expensive test equipment will not show Overunity.  So, one is left to build their own that will show the results that are wanted...ummm...I mean...the real results.  That is why I built this.  It gives any result that I want, therefore, it is very valuable as an O.U. test device.  I doubt that Rose has one of these, if she did, her theory would be proven.
seychelles
HI ALL IF THERE IS A COP OF 17 THEN THERE SHOULD NOT BE A TREVIAL DESCREPENCIES SHOULD THERE .WITH THAT TYPE OF COP ONE SHOULD BE ABLE TO GO TO THE MOON AND BACK..PLEASE SPENT YOUR TIME ON SOME REAL IDEAS SUCH AS TRYING TO PUMP FREE ELECTRONS FROM THE EARTH GROUND. OR FIND A CATALYSER THAT CAN EASILY CRACK WATER..
