Proof of Overunity From Magnets Fixture, No Negative Work Aspect, LaFonte
Started by gammarayburst, September 05, 2013, 03:00:53 PM
norman6538
I don't understand this Butch   - you said
" What is down right  magical is how the two magnets pull a second bar to them with huge force
    but when you just simply  slide one magnet to that second bar the two bars jump to repelling each other."
I think its about this point.
Two magnets lying side beside each other with North up will repel each other but
if one is South up then they will attract each other. Is that part of what you mean?
Amazingly if the two magnets are twisted 90 degrees there is no attract or repel
and twisted 180 degrees and you have the opposite force but it takes work to twist
the magnets and I have measured that force to be about as much as the work you
can get from the twist. What we need simply is a small force applied that releases
a larger force and we at the overunity touchdown.
Norman
elecar
Hi Norman, watch this video   http://www.youtube.com/watch?v=mhfqe2dyR3s
When the two magnets are between the two steel bars they can be manipulated easily.
Now if you place two steel bars the same above the two lower ones it is attracted to the steel bars below. If you then slide one of the magnets between the upper two bars they will then repel each other. If you drop that magnet back between the lower two bars the bars are Strongly attracted again.
gammarayburst
Tinman, that video was just to show the Pseudo Solid effect and has nothing to do with this design.
tinman
Quote from: gammarayburst on September 07, 2013, 10:32:26 AM
@ gammarayburst
Quote: That makes two positive power cycles, one attraction and one repulsion and no negative power cycle at all in the sequence.
Have you actualy built this device ,and tested your theroy?
I am thinking no,as you would have posted a video to show us by now.
There is one force you have missed,and this will become apparent when you build the device-as per the 3D rendering. This is the negative power(as you call it) that you think isnt there.
Can you spot where that will be?.
elecar
Hi Gamma.  Perhaps if you use more than 1 set of bars and magnets you can use the work produced to manipulate the movable magnet in each set.
Here is a crude set up to show how they could be moved. NOTE the disc would be turned by the work done on the attract stoke and is not shown on my simple drawing.
