Proof of Overunity From Magnets Fixture, No Negative Work Aspect, LaFonte
Started by gammarayburst, September 05, 2013, 03:00:53 PM
Floor
@ GammaRayBurst
Floor, I think the plate set would rotate if hinged in the middle but would stop when set went from repulsion to attraction mode. I am thinking that would vary with the geometry of the plate. I doubt it would do a total 180 degree flip.  Maybe more like 45 degrees?
Butch LaFonte
MAGNETS would flip to 90 deg,  if hinged,  or if upon an axle.  I don't know if the two magnets and  plates in (SET B) would behave the same way....  But I think they would also rotate 90 deg. off.
Also I wonder if the magnets in (SET B) could be easily reversed (pseudo solid fashion) WHILE AT 90 DEG. TO (SETS A and C)?
Considering that they would  be under the influence of both (SETS A  and C) ? If so,  (SET B) could then rotate an additional 90 deg. and so on.
                  Thanks for your time/response
                         Keep up the good work
                                  Floor
gammarayburst
Quote from: Floor on October 20, 2013, 12:52:28 PM
@ GammaRayBurst
Butch LaFonte
                                  Floor
Floor, I will do a test and see just exactly what will happen. It's a very interesting question you have come up with.
Butch
Floor
@GammaRayBurst
Hey, thank you for the response.  Based upon your last set of drawings posted,  it looks to me like you've got it worked out.  I hope my ideas will not be a distraction from where yours are going.  This might be premature, but congratulations.
I presume that the ends of the bar sets"A and B" IN YOUR LAST DRAWINGS, where they touch each other, will need to be very flat.  I have some ideas about this,  I will do some drawings and post them when I have time.
                                                         floor
Floor
@GammaRayBurst
Please fin the attached Jpg file "pseudo solid lap joint"
                                  regards
                                       floor
gammarayburst
Quote from: Floor on October 09, 2013, 02:15:29 PM
@GammaRayBurst
I have a question, that I am not sure if you know the answer to or not.
Please see the attached file "PsuSol3.JPEG" drawings and question.
                                              Cheers
                                                       floor
Floor, I made a big mistake when looking at your drawing the first time. I thought that all magnets were in repulsion. I can't believe I didn't look close enough to see that each plate set has two magnets in attraction to each other. This way I hate to say the flux will flow in a straight path between plate magnet sets and run parallel to the next plate set magnets and not offer much repulsion. But, I think I see a design coming out of this that would really open up " Pseudo Solid Principle " so the public will be able to grasp it. I will make a drawing and post.
Butch
Butch
