cyclical gravity greenhouse liquid capillary action energy generator
Started by netwebresearch, April 14, 2005, 10:44:03 AM
netwebresearch
I have got a new idea for an invention. It is a cyclical gravity greenhouse liquid capillary action energy generator. What does your company think of the idea. . The idea is that the device uses the same ammount of liquid over and over again due to evaporaton, condensation and capillary acton to generate electricity. It works like an oil wick using water excpet the energy is genearted as the vapour turns to liquid, and rops through turbines.
The device consists of a liquid chamber, an evaporation chamber, capillary action sheets, condensation collectors, turbines, and liquid.
The capillary acton sheets draw liquid up from the liquid chamber into the evaporation chamber at normal temperatures. then the tip of the capillary action sheets in the evaporation chamber are heated to a temperature where they will evaporate the liquid. As liquid evaporates from the sheets, The capillary actiopn sheets draw more liquid from the liquid cham,ber to replace the liquid lost. The liquid is draw natrually upwards. When the liquid evaporates from the capillary action sheets it enters the evaporation cvhamber. The evaporation chamber is of normal tempertures. It is not the evaporation chamber thet causes evaporation, it is the capillary action sheets. The evaporation chamber is of low temperatures to encourage condensation. Only The capillary actiopn sheets need to be heated. Then teh condensatyion falls into condensation collectors, and is used to power turbines before falling back into the liquid chamber. So the same liquid is recycled.
This is a new invention. Just becayse it uses capillary action that does not make it the same as a solar sill, or paper.
They key is capillary action lifting liquid up for free.
The only heating required is on the ti[ of the capillary action sheets, which can be done by heaters or by solar rays or any other device.
When calculations are made for this device remember it is not a solar heater. Capillary action is key to this device.
Tghis deviceis consistent, Other froms of renewmable nergy are incosnsitent because solar energy stops working ibn times of night, high cloud cover, pollution to sky. Wind power stops working at extreme wind speeds and low or no wind speeds. Hydro stops working in droughts, or when river levels control issues restrict use of hydro power.
This device can power itself.
By the energy gained from dropping the liquid being used to evaporate the liquid. Or can be heated using other heating systems.
Remeber the key is capillary action.
Here is a copy of the diagram for the device the key is
Key for diagram.
1 Evaporation Chamber
2 Condensation collecoter
3, 4, 6 Capillary action sheets.
5 Turbine
7 Liquid
8 Liquid Chambe
hartiberlin
Please attach a GIF or JPEG pic to your reply.
You can add it under the Additional Options...
link left under the message window.
Thanks.
Regards, Stefan.
onthecuttingedge2005
Here is my version of a High Voltage Capillary Generator.
you can watch this video to see how a regular Kelvin Generator works here:
http://www.youtube.com/watch?v=3b23umXzPVA
Jerry ;)
naturefix
Have you built this? Does it not short out in the bottom tank?
