Over Unity (how to get there}
Started by Floor, September 19, 2013, 03:32:41 PM
Floor
@telecom
Thanks for the response
I' not an expert on OU (over unity) I don't know anyone that is one.  To my knowledge, no one has a proven OU device, that can be self
looped and power it's self. I am on this board to learn, and to try to discover or invent, such a device.  Conventional science says that it
is a waste of time to seek or try to prove OU.
You question.  "what is right angle interaction ?
First  let me say that I do not know your level of technical experience, knowledge, back ground etc.  You may be more knowledgeable
than me.  I will try to explain simply so that you, or other readers who are perhaps not very knowledgeable will understand.
So please don't be offended if I explain in very basic terms.
1. A right angle is a 90 degree angle.
2. A right angle interaction of a moving object with a stationary object will transmit more energy from the moving object to the stationary
object, than any other less direct angle. example : a bullet is more likely to ricochet off any object (even a small twig) that it
encounters during it's flight, the farther from 90 degrees the intersection is between the objects.
3. Electric currents are generated in a conductor, when a magnetic field moves across the conductor.  This electric current is at 90 deg. to the mag. field direction of movement.
4. Conversely the same 90 deg. relationship exists when an elect current produces a Mag. field
5. A permanent mag. mounted upon wheels suspending it in close proximity to and above a flat iron surface, will roll across that iron surface easier than it can be pulled from that surface.
6. others
I hope this answer satisfies you question.
                      thanks for the interest
                                          cheers
                                               floor
6.
Floor
@tinman
good point tinman
every device is 100% efficient, when considering all out puts.
It may be that creation is all ready done, all else is transformation.
And it seems that all mater is composed of energy, 100% so.
Is OU defined as the creation of energy ?
Are atoms energy systems that are winding down ?  If they are, does it matter to us within the time scale we experience our existence
through ? Where would that energy go ?  how much energy would it spend to get there?  Poor little energies with no homes to go to !
These are of course, only rhetorical questions, that I am not really expecting any answer.to.
Thank for the thought provoking input
                                                     sincerely
                                                           floor
telecom
Hi floor,
I would add that it should convert already existing in the nature energy sources into the usable energy.
We learned how to do it with the streams and rivers, wood, oil, coal, natural gas, solar light, waves, tides.
Now we have to learn how to convert the most fundamental force - the gravity.
forest
telecom is right
energy is here even you don't see it
simple question : do you believe that a piece of wood has energy ? do you see that energy ? no, you need a special case to release it from wood  ;)
Floor
If one thinks that OU is can't be, then please say so here if you would like to, one time. But then, this is not the topic here. There are other topics here at the OU forum that are not OU topics.
If anyone wishes to debate the possability of OU, please start your own topic as such.
I might be willing to post there.
                                        Cheers
                                                 floor
