Lidmotor's Penny circuit help needed.
Started by Dark Alchemist, September 27, 2013, 02:35:45 AM
Here's what I get:
First, "normal" orientation
Second, the "swapped" orientation: note the negative voltage excursions
It does this with the MPSA18, the 2sc710 and another thing called a "603" that I found many of in old TV chassis.
Legalizeshemp420
Hmm... of course I just realized the signal of the swapped config isn't the collector signal anymore it is the base signal. So if I move the probe, too, over to the bottom of the base resistor/capacitor...that is, still on the collector of the transistor, I get the "normal" signal again.
Quote from: Legalizeshemp420 on October 02, 2013, 09:15:56 PM
I get nothing like that.
Well... hmmm.
Try lowering the input voltage back to 0.5 v
Try using the MPSA18 transistor, just to see if the sim will do what my hardware does
other than that I'm stumped.
My BC337 transistors will probably take a week to get here. They are supposedly coming from Colorado, we'll see, I guess.
Legalizeshemp420
Quote from: TinselKoala on October 02, 2013, 09:26:44 PM
Well... hmmm.
I will tell you that with the circuit you see and changing the transistor (I did this a few times already) to a MPSA18 the BC337 blows it away.  MUCH higher peaks in both voltage and current and the MPSA18 would not do these 4 transistors with the 1.2V whereas the BC337 has no trouble in the sim.
