Self Running Motor Generator - for sale in 3 weeks
Started by e2matrix, September 30, 2013, 01:27:23 PM
ariovaldo
Quote from: ariovaldo on October 07, 2013, 02:29:28 PM
Even knowing that was not possible, I built that using a conventional motor/generator (sculpture)...Guess what?...Didn't work. I tried several capacitor values. Next steps, disassemble it.
Kind regards...
http://www.youtube.com/watch?feature=player_detailpage&v=5Njxw-Y2zPU
vince
Hi Mark
I'm not sure which machine you are referring to in your comment. Are you talking about the original machine with a flywheel that this thread is about or the one that Temporal visitor is developing?
I agree that many of the motor flywheel machines are fakes , having built a few myself that did not run. However the machine (system) that Temporal Visitor is working on has a unique design that  really should be explored further.  He himself has said that a mere motor generator coupling ,even with a flywheel will never work.
Vince
Vince:
I am pretty sure that I saw on Temporal Visitor's web site that his machine is up and running or very close to be up and running and it will be unveiled soon.
So I asked Temporal Visitor the following:  "Temporal Visitor you claim that you have a device or machine but it has not been shown yet.  So when do you plan to show it?  What precisely do you plan to show in terms of the input and output for the device?  How do you plan on making your measurements?"
He completely ignored my basic questions.  Yet on his website there is all sorts of talk about his machine including diagrams and a picture or two.   This is not confidence inspiring.
For all I care the machine could be inside a black box, I just posed some reasonable questions and got no answers.
gotoluc
Kind regards...
Hi ariovaldo,
nice attempt to replicate!... Thanks for making a video of your device under test.
I noticed that you don't have the components in your device that can be seen in Valy's video which I think could be responsible for creating the -90 degrees phase shift between voltage and current (reactive power) condition needed for the motor to turn the generator without causing a load to the generator.
I find it interesting that so far no one has mentioned anything about that unusual component.
At this time I cannot confirm for sure if the principal works but what I can tell you is, a week prior to seeing Valy's video I was doing some tests on a reactive circuit and seeing that unusual component leads me to believe it could possibly work as I've described in my post on page 2 of this topic.
Unfortunately, I will not be publicly sharing information until I have made all the tests to prove it can work or not.
Once I have confirmed it, I will be freely shared the information (working or not) so others can try if they wish.
So until you have identified that component and know what to do with it, your replication attempt may not be complete.
Thanks for sharing
Luc
vince
Hi Gotoluc
In the last two attempts I made at coupling different motors to generators with flywheels I got the same results.  I got the units running with the flywheels at high speed and had voltmeters on the generator output. When I flipped the switch from mains to loop mode it always did the same thing. Within a fraction of a second after the switch ,voltage degrades so quickly that no motor could even run for a short time.
I remember seeing a an article (don't remember where) of a person using a(sta-volt) in his system to compensate for voltage decay in the first moments after switching modes. As I understand it a sta-volt is a brand of voltage regulator that can adjust voltage when it drops or increases within it's range.
Could this be one of the missing components coupled to some type of capacitor array?
Vince
