Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
synchro1
@Conradelektro,
                        Those are diametric magnets in the picture above. After you wind your diametric magnets for the "Synchro Coil" try connecting a fast switching Shottky diode in series between the leads of the bifilar coil and your 10uF capacitor. Place multi meter electrodes on the capacitor poles, and you'll will find that the diametric magnet core coil actually begins to generate power spontaneously, up to a ceiling charge, then stops. This is what Cook maintains his battery does.
                         Cook requires that the ferrite cores be "Charged". One apparently has to start it by running current from a battery backwards through the coils to magnetize the cores. Rather then deal with this problem, I just substituted those powerful diametric neodymium's to run tests on, and voila, I got results!  I discovered that the Tesla series bifilar solenoid will generate spontaneous power while standing still with a stack of diametric ring magnets positioned in the core. You will be able to measure this overunity effect for yourself from your finished "Synchro Coil". Prepare to be amazed!
I made a video demonstrating this effect with a quadfilar wired like the Cook battery:
http://www.youtube.com/watch?v=9XMfCpUzq_g
P.S. Please do not attempt to replicate this Intercom coil experiment. Several people tried and failed and I
grew exasperated trying to describe how I had it wired. I am currently confused.
conradelektro
Quote from: MileHigh on December 21, 2013, 12:28:19 AM
You probably saw where I said that magnets don't affect coils because they don't produce changing magnetic fields.  So if Conrad does some tests he could check for that.
So the logical thing to do is to compare it with an air core coil and a coil with a normal unmagnetized ferromagnetic core.  If you don't have a ferromagnetic core you can use nails of course.
So before even making the measurements the presumption is that the possible output power will increase as you go from air core to the synchro core to the regular ferromagnetic core.
Quote from: MileHigh on December 21, 2013, 12:52:55 AM
For starters, the basic idea is just to use a single resistor and not use an FWBR at all.  Then you simply look at the waveform on your scope and if your scope can measure true RMS voltage then you get an output power readout.  Or you can use a true-RMS multimeter.
If you measure the resistance of your coil, and then use the same resistance value for the load resistor, then you will dissipate the maximum power in the load.  Note that the same amount of resistive power is being burned off in the coil itself.  So the "true" power output is arguably the coil resistive power plus the load resistor power.  When you measure one you know the value of the other.
This is actually the heart of your experiment:  You try air core, synchro core, and regular core for different values of load resistor.  You make your input power measurement going to the pulse motor and your output power measurement going into the load resistor or the (load resistor + the coil resistance) and compare.
You know that with a regular ferromagnetic core and using a load resistor that has the same resistance as your coil resistance, you should be extracting the maximum power from the spinning rotor.
Understanding the concept of impedance matching is of prime importance for understanding electronic and mechanical and other types of circuits.
So this is a study of different pickup coil configurations and how they output power into different values of load resistor.
@MileHigh: Thank you for taking the time to explain a good measurement technique. This helps a lot and I will try to do the measurement exactly as you suggest.
My scope should be able to measure true RMS over the load resistor.
I just wonder whether the bifilar coil will have a different DC resistance with an air core, a Ferrite core and a magnet stack core? In any case the coil will have a rather low DC resistance around a few Ohm (because I will only wind about 500 to 1000 turns of wire on that coil)? Does the type of core have an influence on direct current going through the coil? Probably a silly question.
It looks like I can do some work in my lab on the 29th and 30th of December.
Greetings, Conrad
Conrad:
If you make a regular coil with say 500 turns, then using the same wire you can make a series bifilar coil that is 250 turns + 250 turns.  So you have two coils with the same physical dimensions and the same total number of turns.  The wire length will be almost the same so they will have almost the same DC resistance.  The coils will measure the same DC resistance independent of what material you put in the core or if it is an air core.
When you work with the two coil configurations, I am assuming that you will test them as pick-up coils and try different load resistors and cores, etc.  Like I stated before, you can expect that you will not find any significant differences between the regular coil and the series bifilar coil when you do these types of comparative tests.
You can look at the core as an energy storing device.  The core stores magnetic energy that is proportional to its relative permeability.  So we know the relative permeability of air is one.  A regular ferromagnetic core might have a relative permeability of 800.  The magnet stack core is anybody's guess.  I will take a guess that it will be about five.
The more energy that can be stored in the core the higher the measured inductance of the coil + core combination.  It's easy to do pulse experiments where you measure the amount of energy that can be stored in the coil + core combination at different current levels.  When you make those energy measurements you are also measuring the inductance.  So you can use this measurement technique as a way of double-checking what a digital inductance meter measures.
Good luck on your experiments.
synchro1
Quote from: MileHigh on December 27, 2013, 09:22:38 AM
Conrad:
@Milehigh,
The "Synchro Coil" is a "Satellite Coil" not a pickup coil, and does not have the same physical dimensions as a pickup coil. You're outlining a completely different test from the one we started out with. What are you trying to pull here? The test you devised here is to compare a single wire pickup coil to a series bifilar pickup coil of identical dimensions! This is completely irelevent to the test of the magnet core coil! The magnet core coil is designed to generate power from within, not from the spinning rotor. Try and remain relevant while contributing to this thread.
conradelektro
Quote from: synchro1 on December 27, 2013, 02:36:49 PM
@Milehigh,
The "Synchro Coil" is not a pickup coil, and does not have the same physical dimensions as a pickup coil. You're outlining a completely different test from the one we started out with. What are you trying to pull here? The test you devised here is to compare a single wire pickup coil to a series bifilar pickup coil of identical dimensions! This is completely irelevent to the test of the magnet core coil! The magnet core coil is designed to generate power from within, not from the spinning rotor. Try and remain relevant while contributing to this thread.
I am very grateful for MileHigh's contribution which is highly relevant for the test of the "synchro coil".
If the "synchro coil" shows any unexpected behavior it will be even better visible with the measurement method (only a resistor which matches the DC resistance of the coil) proposed by MileHigh because one would get the most energy out of it.
I will also make a test with a full bridge rectifier and a capacitor but first all parameters have to be established (DC resistance of the coil; the inductance of the coil with different cores; true RMS Voltage over a matched resistor with different cores at different distances of the coil from the rotor; slowing down of the rotor when the coil, shortened over the matched resistor, is placed at different distances from the rotor).
Synchro1, you should not piss off people like MileHigh who try to help by proposing a meaningful test procedure. Only meaningful and well executed tests can show the truth behind interesting observations.
The aim is to measure any unexpected behavior of the "series bifilar magnet core synchro coil". A big part of it is to compare the behavior of the bifilar wound coil with different cores (air core, Ferrite core and "tube magnet core"). And then one has to wind a similar coil with just one wire to establish any possible differences. That will give some insight.
According to Synchro1's opinion the "synchro coil" should "generate power from within, not from the spinning rotor". And I will try to shed light on that with my tests. But first all parameters have to be established as MileHigh says. Otherwise we just fool around. We can only proceed from the known towards the unknown in an orderly way.
Greetings, Conrad
