Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
synchro1
Quote from: MileHigh on December 31, 2013, 03:19:21 PM
Synchro1:
Here is Igor's second clip again:
http://www.youtube.com/watch?v=mzNjAs3-9LA
Look at the left digits on the power supply showing the current draw of the setup.   When Igor inserts the ferrite rod into the core of the coil tell us if you see the current increase.   When he removes the rod tell us if you see the current decrease.
Note also that he is most likely crippling the usefulness of the ferrite rod by attaching the magnets to it.  Chances are the LEDs would have gotten much brighter if he inserted the ferrite rod alone without the attached magnets.  Notice however that he never makes that test, he failed to do an A-B comparison of rod with magnets vs. rod without magnets.  Naturally without making that test there is a possibility that you could lead yourself down a garden path and make incorrect conclusions and inferences.  The more information you have to work with the better off you are and the better your understanding of your test setup.
Those very tiny incremental changes on the display can't account for the blazingly bright increase in LED intensity! Igor states that there's an overall increase in voltage and current output, and he went further to report a rotor acceleration as well. He starts the video by visually by speeding the rotor up while holding the magnatized ferrite close to the rotor. You can very easily see the ferrite chasing the rotor. Look at the video by Ibpointless2:
http://www.youtube.com/watch?v=AN37ruFKrhs
synchro1
@Milehigh,
Have a look at this video on the "Macroscopic Aharonov-Bohm effect":
http://www.youtube.com/watch?v=ugxmtT4FUME
This relates to the "Vector A potential" of Dr. Richard Feynman; The vector A potential is not confined to the magnet core, and is located along the axis of symmetry in the toroid schematic below!
Conradelectro sadly failed to harness this charging effect because he overwound his "Synchro coil".
synchro1
This video is very informative, and demonstrates self assisted oscillation power output:
http://www.youtube.com/watch?v=iJsVSMQqCOM
@Conradelectro,
                        At 3:15 in this video, a quote appears that reads as follows:
"Winding a coil or helix now needs a bit more thought! Spin of the "A VECTOR POTENTIAL" and the dynamic movement of it needs to be accounted for.
Quote from the Youtube comment:
"I show the importance of knowing and understanding the A Vector Potential and how simple it is to create a "self assisted oscillation". This set of shorted Self Assisted Oscillating Coils. This can be improved hugely and is possible to be made to self run with this technology. Nikola Tesla, Floyd Sweet, Lester Hendershot, Edd Leedskalnin and Daniel McFarland Cook all knew about this technology. They all used it in various ways to improve their devices"....
synchro1
@Conradelektro,
There's one more test you can make on the "Synchro coil" that you over wrapped. Wire a fast switching diode in series with a capacitor between the two coil leads and check the capacitor for spontaneous charging. Please check for this self oscillated charging effect. This is just a ten minute job! Would you be willing to a least try that?
I noticed the fastener nut you choose to connect the DC motor drive shaft to the rotor axle with that large set screw jutting off to one side. That really looks very professional. You could probably get it going faster spinning it by hand! Fine example of precision craftsmanship.
What's that piece of crap have to do with the thread topic?
synchro1
Quote from: conradelektro on December 18, 2013, 08:19:59 AM
Thank you Gyula and synchro1 for your explanations.
To clarify for all readers what synchro1 proposes, I made a drawing of the "synchro coil" (a generator coil).
I do not realy see the connection (the equivalent components) between a "Gary horshoe magnet neutral line / plate near the neutral line" and what synchro1 proposes (the "synchro coil" near the spinning magnet)?
Synchro1 could you formulate your thoughts on the connection between the "Gary setup" and your "synchro coil"?
I understand that Gyula envisions the generator coil on the plate near or exactly at the neutral line in front of a horse shoe magnet (what I call the "Gary setup").
The Piezo actuator sounds great but it is too early for me to go into that. I want to experiment with a "synchro coil" near my two magnetspinners first. May be one has to go back to the "Gary setup" with a coil on the plate and glue the plate to the Piezo actuator?
Greetings, Conrad
P.S.: "Gary setup" is Fig.1 to Fig.4 from synchro1's post http://www.overunity.com/13852/self-accelerating-reed-switch-magnet-spinner/msg379824/#msg379824
