Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
picowatt
Quote from: synchro1 on January 10, 2014, 11:06:46 AM
@Picowatt and Conradelectro,
try a: 1N3712. In the meantime have a look at this "Leon Dragone Magnet Pump Video". You can see a closeup of the electrolytic capacitor and diode I use. The disk magnets on the coil are the most powerful available on the commercial market.
@Milehigh,
I prove here in this video, that I can generate power without moving magnets over the coil, outside the restrictions of "Faraday's Law". The magnets are in attraction. The coil is pulsed through the reed switch, then power is generated in the coil when the permanent magnet field reestablishes itself inside the coil! I produced this video to demonstrate the viability of the the "Synchro coil" theory you flagrantly scorned! There are no moving "Faraday magnets" in this magnet pump! Dr. Dragone maintained his simple magnet pump was COP>40.
http://www.youtube.com/watch?v=q5WSPMeWGdE&list=TLvfF6ZA57LvV7eDFDeue0XosYGWgsP5s9
Here's a second one with a clear view of the power reading:
http://www.youtube.com/watch?v=jBPKO9qSfGk&list=TLvfF6ZA57LvV7eDFDeue0XosYGWgsP5s9
Synchro1,
The 1N3712 is useless in the THz band.  A quick look at the setup in your video tells me that whatever you think you have going on, it is not likely to be happening anywhere near the THz band.
PW
synchro1
@Picowatt,
I realize that. The "Synchro coil's" resonant tank oscillation is in the megahertz range, close enough to gain excitement from the higher frequency. This is a magnet assisted oscillation! The power comes from the LC tank oscillation. The tank oscillation acts like a step down transformer. You have to match your electrolytic capacitor value to your series bifilar windings inductance so the resonant frequency's in the diode's catch range.
Some Radio shacks usually stock one hi-frequency glass diode that will work. They can order it if it's not readily available. It can help to go with a higher frequency broader spectrum diode like the tunnel germanium I recommended, but the Radio Shack inventory will work.
I thought there was a better close up of the diode then appeared. There's a close up of one in the intercom video. Just fast forward to 6:22 in the video:
http://www.youtube.com/watch?v=9XMfCpUzq_g&list=TLIIucQXNfeEQeX8aSPjZQXw9pbykaf9I7
I used powerful 1/2" x 1" coupled diametric neos, lightly wrapped in fine wire series bifliar. I never tested weaker magnets. The LC tank oscillation would normally peter out with out added input. The powerful neos alone are enough to sustain the oscillation, and continually charge the capacitor! I've been calling this the "Cook effect", after Daniel McFarland Cook, inventor of an eighteenth century magnet battery. Mine is a simplified version. I find it simple to get the effect. I tried different types of diodes, and the hi-frequency types perform the best. How large are the most powerful magnets you own?
picowatt
Quote from: synchro1 on January 09, 2014, 02:41:22 PM
What Milehigh doesn't understand is that the "Synchro Coil" is not an induction coil, It's more of a Radio reciever, but the sine waves it rectifies are just outside the radio frequency bandwidth in the Teraherz range.
Synchro1,
I was merely disagreeing with your claim regarding the rectification of THz range sine waves.
That is very, very unlikely with your setup.  If the propagation and rectification of THz sine waves were happening with your circuit, that would be as much or more so remarkable than any overunity operation.
http://en.wikipedia.org/wiki/THz_gap
PW
synchro1
Quote from: picowatt on January 10, 2014, 04:12:22 PM
Synchro1,
PW
@Picowatt,
Take a look at this link on terahertz diode:
http://coolcadelectronics.com/portfolio-item/infrared-rectennas/
synchro1
Quote from: TinselKoala on January 08, 2014, 08:26:16 PM
That earns a ROFL, for sure. Just what does a terahertz fractal look like on a DSO, I wonder.
If you want some credibility, synchro.... why don't you present some _evidence_, like demonstrations of your own, that show some of these remarkable effects you claim.
You'll have to wait for me to return from Costa Rica to the shop in Northern California. I just posted two videos of the incredible effects; You've probably already seen them both. One : Leon Dragone's magnet pump, and Two: the intercom coil. Have another look!
The Terahertz fractal I'm speaking of would appear as an increased charge rate. I talking about an LC tank resonance tested for with a variable capacitor.
