Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
kampen
Well, it's not just "a heater"...It's THE heater!
We are talking about great efficiency here. For example, supposedly, if water tank with 4lt of water needs 10.000 watts of energy to raise the temperature from 40 to 80C degrees in 3 minutes, this device would need half of that power! The phenomenon belongs to sympathetic vibratory physics sector and a guy called Peter Davey, who used to play sax, has done the same thing using two pieces of metals, cut properly and inserted one inside the other so they resonate and the two of them, when plugged to mains, produce almost infinite harmonics. It boils a glass of water almost instantly!
Source https://www.physicsforums.com/threads/way-of-producing-600khz-longitudinal-waves-piezo-or-siren.841200/
partzman
Quote from: synchro1 on January 05, 2021, 12:53:14 PM
Here's a spherical ultrasonic piezo motor rotor! A Tetrahedron of piezo chips is the best Resonator cavity.
In case anybody is interested in the source for this device, the pdf is posted below.
Regards,
Pm
synchro1
@Partzman,
Thanks for the PDF. The wire wave guides run a polycarboante rotor, but could easily run a neo sphere. The wires act as a wave guide for the transducer. The copper wire wave guides could double as electrical output coils in resonance. Voila! The spinner could also power a group of Lidmotor "Maggie's". Replacing the plastic rotor with a neo sphere, accelerating electron spin with resonant ultrasonic piezo excitation and collecting output through the wave guides to diodes and storage capacitor. Ultrasonic acceleration of neodymium electrons! Nuclear acoustic induction motor generator. This could be the next generation of electric motor generator! An important innovation. We can control the wave guide gap with Lenz drag and collect the rest circumferentialy.
Át 2 minuites into this video we see the Keely Sonic motor.
https://www.youtube.com/watch?v=rYrdiQckGhw
synchro1
It may help to cover the neo sphere with a thick polycarboante coating. The magnet sphere could drive an outer magnet wheel by induction clutching and function as a synchronous nuclear induction motor from the inside out.
synchro1
A polycarboante coated neo sphere between two piezo transducers connected by two wire wave guides to the ball inside an output coil core would be assured to work. The rotor sphere would respond to a full range of acoustic power control settings and frequency ranges.
The last design ran at a fixed frequency. This upgrade adds a tuner! A more highly acoustic responsive coating adds flexibility. Simply impregnate the plastic rotor ball with a neo sphere!
This be by rights of Three Prone Bones flag of Richard England!
