MCP1406/07 MOSFET DRIVER
Started by Jeg, September 30, 2013, 03:53:33 PM
Jeg
Jeg
I have this with a 10.000μ permeability. (Fair rite) but the cable is too thick for making 17 turns inside there. I will put something smaller and give it a try.
gyulasun
There is problem now that you wish to use the input transformer: the MCP chip may get burned the fist moment it is switched on because the DC resistance of the coax cable is but a few milliOhms, letting a quasi short circuit appear the chip output if the series 3 Ohm is there than it is the only resistance to limit the shorting current. To remedy this, a coupling capacitor of a few uF should be connected in series with the 3 Ohm to block DC current.
Jeg
Revised Diagram after Gyula's proposals
- One Resistance 3 Ohm after MCP1406
-Electrolytic cap 4.7μF after the above resistance. For Frequencies above the audio range this cap should be smaller.
Jeg
Jeg
Gyuila my new load inductor at mosfet's side is 20μΗ. At 500Hz minimum rate it will be like a shortcut. Is it a good method to put a resistor in series with the inductor? Can I get over it by just having a very short pulse through the pwm?
