Stivep1: Tesla Rehash (Akula device)
Started by jbignes5, October 02, 2013, 10:19:57 PM
stivep
http://youtu.be/SS_CsCX2SHc
Wesley&John:About Akula,LithuaniaExperiment,Rossi
I hope you will find it  educating and interesting as well. There is some addition to understanding How Akula works plus new light on the general subject.And for these who  is looking for easy free food - sorry if you do not  read watch and learn - you last in the row of potential benefitsiants  .
Wesley
d3x0r
So I was going to go about implementing this and there are subtle differences in the schematics so I guess it is the complete picture.  Although both sides are the same PLL and phase advance(retard?) logic with subtle differences in frequency range selections and sources of inputs...
in the latest videos, the tall white coil will be the receiver, and the extra windings at the bottom are where the load will go.
It(receiver) resonates at a base frequency at 1/3  (50Khz not 150Khz).  The transmitter resonates at a higher frequency.  It looks like both are driven to their own resonant frequency;
The capacitor across pins 6,7 on CD4046 is 1n on the receiver and 2n on the transmitter.
On Trasnmitter there is an additional transistor KT503(?) on the transmitter to drive pin 3 on CD4046; on the receiver pin 3 goes to pins 4 and 5 of 74hc14; on transmitter pins 4,5 of 74hc14 are only connected to each other.
on transmitter capacitor to pin 9 of cd4046 is 240n instead of 100n(receiver).
the drive to pin 14 is handled differently (block change) (block change 1)
On the receiver there's an extra diode from pin 7 to pin 1 of 74hc14
on receiver resistor from pin 13 of 74hc14 is 10ohms; on transmitter it is 5 ohms
on receiver pins 9,10 of 74hc14 gots off schematic to a jumper and to coil diagram
(block change 1)on transmitter pin 9 of 74hc14  goes to IR2111 mosfet drive
        pin 10 of 74hc14 goes to the transistor to pin 14 of cd4046
(copy and paste includes a size change for some reason; maybe I have my page zoomed)
So they are not the same schematics;   the transmitter is mistranslated as a title, and is the one with the K555 (555 timer) the receiver is the one without the K555.
stray thought: so this is actually a good schematic to represent John hutchison's effects; He claims to use 2 tesla coils and a static field (van degraff) at interfering frequencies; and these are more about keeping the frequencies the same..... John huchison's work was utilized by ken shoulders to create EVO (exotic vacuum objects),  which is similar to mark leclair's cavitation process...
NMR?  maybe sorta... in a sense there is a relatively static field and another field moving through it... (a 1/3 wave is almost static compared to the 3x frequency moving through it... ) not at right angles... could be built at right angles...
Caduceus coils; none in this case... they do have frequencies where they apparently consume power, resulting in potentially a voltage sink, which should be continously satisfied by ground as a working theory.... but I don't see any such interfering coils here, they are all concentric.
what probably happened with the nano pulser in dally's gear is that it triggered a feedback wave and resulted in continuous avalance motion of the transistor... which would be in sync with the driving pulses; especially at forced resonance, the reinforced wave would exceed the collector making it not a GNSI but a phase regulated high voltage wave...
d3x0r
I don't know if you've been following this guy...
http://www.youtube.com/watch?v=a5aajLyTHjI
Probably not a lot of new perspective but is another work in progress.
stivep
d3x0r
I don't know if you've been following this guy...  http://www.youtube.com/watch?v=a5aajLyTHjIProbably not a lot of new perspective but is another work in progress.
thank you my friend for information. I did not  but I will now :)
http://www.youtube.com/watch?v=x67q0WOcXCg&feature=youtu.be
http://www.youtube.com/watch?v=mPAd-VTHjfs&feature=youtu.be
http://www.youtube.com/watch?v=K5NnXOHb0Jc&feature=youtu.be
Wesley
