Stivep1: Tesla Rehash (Akula device)
Started by jbignes5, October 02, 2013, 10:19:57 PM
Hope
This validates what John Hutchinson says about mixing physical fields of bandwidth from different outputs.  Does this somehow increase or decrease the compression of the aetheral materials.  Is what we can measure only the effect it has on the physical atomic structure?  I know we are not pursuing a discussion of aetheral anything here, but there is some unknown knowledge that we do need to understand.  All the hit and miss of a multitude of working then NOT working devices suggest an unknown.
d3x0r
Quote from: br549 on November 11, 2013, 03:49:33 PM
d3x0r:
I'm not exactly sure why the two coils of the magnet coil circuit is connected the way it is yet?
aAs Always: have a good day
I see; this is just akula's postings on realstrannik; starting at this message is the only pictures of assembly of his latest coil, but he doesn't show the first layer...
http://realstrannik.ru/forum/48-temy-freeenergylt-antanasa/134547-akula0083-soobshheniya.html?start=54#166738
maybe there's video...
I dunno, maybe the other leads on the photo are to the aluminum coil? looked through akula's channel, he goes from having nothing to having the coil and driver coil wrapped (presumably the other coil and aluminum too)
It looks like there's an extra coil on the schematic that isn't wound, but maybe I'm missing something.
br549
d3x0r;
I have some opions based on my limited understanding of the system, but am hoping that Wesley may be able to shead some light 8).
Wesley:
In your opinion, do you think that the below wave form, in
reference to the Receiver Coil is what is being generated with
the oscillation and sync. Circuitry????
As always: Thank you and Have a great day. :)
br549
forest
In the videos you posted stiveip there is a lot of accusation about using ground is probably fraud. I agree, that may be the point, but do you know any simple way to avoid ground and make floating device ?
If there is excess energy produced it's obvious the original power source is not able to withstand it and all is radiated as heat which immediately burn the device ! Actually I believe every strange accident in electrical apparatus is the manifestation of ungrounded energy excess....  ;D
Has somebody ever thought how to limit the current returned to the power source ? It is against Ohm law so must be related to transmission line, inductance and similiar. However at 50Hz there is not much to be done, because any LC filter would be enormous
