Violation Possible of Newtons Law
Started by Hope, October 08, 2013, 04:02:11 AM
Hope
Using the example of a series of masses moved by a rail gun.   The violation can be by making the first mass weight kinetically shift by spinning it to direct the kinetic energy 90 degrees prior to firing.  Then the force comes as if from nowhere that effects the forward movement.  Like all theory,  let this general idea move into all your ideas of where to get the energy from or to.   When we dissipate the energy at the end of movement this way will other energy be pulled along in its vacuum?  Like all general theory it will apply to many specific fields in movement, so let your imagination run wild with this template.
A simple useful application of this would be how to deal with water force stopped in pipes.  I know they use spring plungers for this now.  But to divert this into a spiral, ending in a circle will have only water working and not wear out "parts".  Maybe there is useful work this energy could do in this or other applications.
s3370389
Hi Hope,
I am having difficulty understanding what it is you are trying to say here. Could you possibly break down what you are trying to say into concise points and with free-body-diagrams?
QuoteBut to divert this into a spiral, ending in a circle will have only water working and not wear out "parts".
Are you referring to cavitation?
Best regards,
s3370389
Hope
No not any cavitation effects would do what I am saying.   When a weight is spinning its inertia is shifted beyond the physical mass of that weight on an lateral plane.  As the weight is at rest the entire weight mass in equally distributed through out the mass.  But when the weight begins to spin the inertial mass is felt as a kinetic energy and the inertia moves toward the outer edge of the spinning weight.  The faster the spin the more it is distributed to a equal amount at all the radials degrees of that spinning plane.   So as this spin increases the outer kinetic radial gets larger,  since the physical mass does NOT increase it becomes distributed over a greater and greater area.  This means that to cause the entire weight to move in a desired direction requires only enough force slightly greater than the weight distributed to the radial you wish to move in.  Example would be to imagine a 36 pound circular weight not in movement on an axle.  The weight felt on the axle is 36 lbs. (of course the earth is always moving but is not effecting it for this example). Let us imagine as we spin this weight the axle feels this weight distributed evenly on all sides of the axle.
http://www.youtube.com/watch?feature=player_embedded&v=JRPC7a_AcQo
So of course the faster the spin the finer the distribution will become therefore the less force it will require at a any given point to cause movement in the direction desired.
Now imagine that the force is applied with a constant signal wave such as to match the force to the exact same spot on the axle each rotation.  When the spin is great enough we could also use the a wave form signal to "push" on the outer inertia constantly to also increase the spin rate.  Friction could be overcome by using magnetic bearings in a vacuum.  All and all the faster the spin the less energy will be needed due to the kinetic footprint becoming larger.  Similar to a pulley that needs less horsepower to do a job.  It will do the job slower yet with less needed push,  you of course will need the same amount of power overall IF you were lifting a dead weight.  But we are talking about moving only a small part of the spinning inertia to cause imbalance and movement.
If we spin up a payload before sending it to space would not the amount of fuel needed to be used getting from after liftoff to trajector be far less?  And every pound of fuel less would mean efficiency of lift would be greater.
As this payload moved many pulses on the axle at various areas could keep the imbalance happening with only fractional energy compared to a dead lift.  Maybe it is how the UFO videos we can find and view are moving,  I have noticed they are not smooth in their movements.  There would have to be a sacrifice in regards to efficiency or smoothness and this could explain why we see the uneven flight paths at slower speeds on the UFO videos.
Overall it would take perhaps 3 spinning disks at say a 45 degree angle to be practical in keeping a acceptable course trajectory.  This would allow movement in a 360 degree plane  (any direction we wished in the 3D Dimension)
Pulses at 0 degrees (greatest force)  then 120 degrees and 240 degrees of equal value would keep stability and cause vertical climb straight up if applied to all three disks synced.   This configuration would look a great deal like a 3 sided pyramid if the lines of force we only considered.
Edited various times to prevent timeout.
Hope
New Video Evidence Linked.  Don't Miss This.
Hope
Anyone know of a decent free CAD ware.  I will make some drawings,  seems to me this idea will work.  That link shows the principle and could be acceptable as a prototype proven.
