Building a self looping "SMOT"
Started by elecar, October 08, 2013, 03:34:35 PM
lumen
I think one could just machine it from a solid plate of aluminum about 1.25" thick.
Could first layout in cad to get a good passive crossover where the rail furthest from the magnets would taper closer to the other rail until the ball just falls over it onto the exit track. This could be done smoothly as to cause no change in height of the ball. (almost)
DreamThinkBuild
Hi Elecar,
Thank you for sharing your design and video.
I'm interested in your original track. What is the length of the track in the video?
I also attached a picture of a possible circular design(minus support structures to reduce clutter). It's an untested idea so it may or may not work.
It is at an exaggerated scale to show the curve better, the angle and curve would be a lot less perceptible. The idea is the same as yours but curved and where the ball would usually start to fall back down the ramp there is a very slight gradient tilting it towards the down side.
The way to build would be to make two rings of wire for the track, inner and outer. Then slightly bend the inner ring at the top towards the down side where the ball starts to fall  back. 3D printing is also an option once measurements are nailed down.
norman6538
Elecar this is very exciting. By using only one side of a smot you left the other side
open for the escape. I have always believed that permanent magnets can do work because
of 1. Finsrud's device and 2. my pendulum that swings higher than its dropped point and
3. now your modified smot......
Thank you very much....
I will stick one together tomorrow I hope.
my pendulum drops from 2 oclock and travels to noon here.
http://www.youtube.com/watch?v=4FzK2XKQ-74
Norman
lumen
I think there's more to it than that, just like a steel ball will always pull to the edge of a magnet because there is less attraction in the center.
So the main acceleration is pulling into the magnet and there is less attraction in the center of the ramp, but can be controlled by the magnets angle to the track.
The idea is to gain moving into the ramp and exit just after the peak of the gain and where there is less attraction.
May be?
Pirate88179
elecar:
Wow!  I have read this topic and seen your video.  I think what you have devised is brilliant Sir.  I have no problem taking you at your word, even though we here on OU.com have been burned before as we all know.
I believe everyone should read your first post and respect your position.  You spelled out what you would, and would not reveal.  I accept this.
Once your idea is fully understood, selecting the materials for easier building for the experimenters is where the folks here can contribute.  We all have to work with the tools we have and the materials we can easily get.  What a great job you have done using that metal bracket.  I wish you much success and I appreciate your willing to share with us on here as much as you are able.
If I were in your position, it would be killing me to not be able to do so.  Very well done Sir.
