Toroidal Coils
Started by d3x0r, October 22, 2013, 06:56:51 PM
Bob Smith
Quote from: d3x0r on July 10, 2020, 07:57:54 PM
And anyone PLEASE explain to me
https://youtu.be/04-kWptAiV8?t=438
This is AIR COREs...
I know... I have a bunch of stuff scattered all around, it REALLY isn't that much, which is why I'm confused by the confusino of the mess... can you not just follow 2 wires?
How does the pulse NEVER go negative?  Where does it go?  it's really just an oscillation above 0 DC....
look
    LoadA  - toroid coil - load B
              (air gap)
                 toroid coil
               oscillator
the bi-filar coils are connected in series, with that middle tap being ground, and you get positive and negative potential on the other side. ...
after you get the system started you can remove the ground, but initially you need some free source of electrons to have some motion in the system.
Are you using an AV plug? I believe that will keep things unidirectional.
Didn't watch the whole thing, but a schematic would be helpful.
Bob
d3x0r
Yes, there is an AV plug on the one side... the other side was a capacitor which the other side is to ground, so there's no direct conduction path to ground...
the AV plug is across a sizable cap... it sort of determines the amount of power availalble
d3x0r
Sorry I'm confusing setups I did try a variety of setups..
cap                            - avplug - coil - LED load - ground
(in parallel with cap) incandescnet bulb
nope other setup was basically the same thing, but A and B on the sides of the coil are swapped...  (there is a grounding point in the middle, if there's not enough free electrons flowing, loads will be dimmer than they should be  (once the system starts, there's capacity in the magnetic field and capacitors that need to be filled... once there is that, I don't think the ground is required; the electrons shouldn't be consumed in their reactions to generate like light ... or even drive a motor...
d3x0r
And I didn't get a chance to record it - I don't know how to 'let the air out of the tires' so to speak....
I was having problems getting the ends to be +/- so I grounded the other end, and they started oscillating right, reconnected the load,
got much more output, disconnected the ground and everything was still the same
turned off all the power and started again and ... the good state; so I don't know
how to provide 'if you see this, maybe you want to try this...'
d3x0r
For the electrical engineers... If I count the turns, and count the radius, and get an LC, and measure that LC for a coil to be the same, the coil IS the same as any other coil of similar LC?
Then how would anyone ever know the difference.  This is NOT tough; and there is no trickery in the jump cuts.  No video I make and post or promote has ads or is expecting some personal gain from you watching it.
https://www.youtube.com/watch?v=zuIiA7TWzmY
https://www.youtube.com/watch?v=TUZyoQwoG9c
J
