I need free part's supplier's for 220+ volt overunity system
Started by Troy Olson, November 01, 2013, 03:17:30 AM
And yet you cannot refute me at all, there, can you GMeast.
Does energy come in "Volt's" where you are? Do you even know what a "grocer's apostrophe" is? When someone claims something but cannot provide any evidence, and makes so many errors per sentence that it's not even funny any more, what do you expect?
Does that give you the right or privilege to ask that someone supply you with free parts?
Are you stalking me, still, with your baseless insults and threats?
Why don't you go crawl back under your bridge and play with your pal, the lying Rosemary Ainslie.
I want to see real, honest researchers here who have DONE THEIR HOMEWORK and don't make stupid errors like claiming to produce "Volt's of Energy". This wastes everybody's time. What do you want to see, more Ains-lies? More "monetized" videos making false claims, in order to get clicks and ad revenue?
You can mock my handle all you like. Every time you do, it's another poke at Archer (spit on the floor) Quinn, and I LOL.
Troy Olson
Actually cold koala my device makes multiple amperages that are added together to make several Volt's. It actually work's off of what I call the ARE theory,which is Action +Reaction=Energy to Infinity. And in case you didn't know 220 Volt's is actually wrong I goofed I'm actually going to build the device to have an output of 240 Volt's which is the average power that is supplied to most households in America. It's amazing how some people tend to talk shit without doing their homework first.My device is designed to also work in a vacume space it doesn't need any type of atmosphere or oxygen to work,it can be built to also keep it's internal temperature at the optimal temperature level in any environment whether the environment is hot or cold from the power it makes and still also supply the level of power needed for whatever it was built to supply power for.
Troy Olson
As for the other fellow's who have taken time out of their day to respond to my post I would like to thank you for taking the time to read and respond to my post.
Troy Olson
Nobody makes a half million volts at a time "dumboala" the highest rate of power that is made and transfered is 50,000 volt's. And you really should look at that thing in your house called a power box it say's in plain English or whatever language is used where you live that the power being supplied to your house is no more than 240 Volt's.I'm starting to think you don't even know the correct order of electrical measurement.
Newton II
Quote from: Troy Olson on November 02, 2013, 03:57:14 AM
Actually cold koala my device makes multiple amperages that are added together to make several Volt's.......
Are you talking about bezentropic electricity?
Properties of bezentropic electricity :
1) By adding multiple amperes we will get several volts
2) By adding forward volt power to reverse volt power we can get infinite volt power
3) 220 volt power can be goofed to 240 volt power
4) BE can be produced at   -273K  to fusion temperature with level power
5) The upper limit of bezentropic electricity is 50,000 Dumboala volt power.
Anything else ?????
