JT first attempt
Started by lygeas, November 13, 2013, 11:07:16 AM
lygeas
@TK
Thank you for your replies and the circuit you posted. I have to admit that it is a bit complicated for me at this point of time-but I keep it in mind because its very interesting.
Trying to understand the joule ringer, I ve made another circuit that when using a capacitor I measure almost 20v and-when I measure it as open (from led to negative see attached photos) I have only 12v. I believe that the appropriate way is using the capacitor and not the second one.
I wanted with this circuit to create a high voltage JT. I will try it with a bigger torroid to see what measures I will have.
I hope to be able in near future to light a cfl lamp (instead of the led now) with a similar type of circuit.
d3x0r
High voltage Joule thief...
This is best done adding another winding of a lot of turns... if you try and do it with the drive you'll exceed the voltage of the driving transistor.
lygeas
Quote from: d3x0r on November 24, 2013, 05:51:01 PM
Dear d3x0r
Do you  mean to add another winding to the secondary coil?  if i use a 2n3055 transistor will I be ok?
Thank you
I dont understand what happened with the photos that i tried to upload.I will retry.
d3x0r
Quote from: lygeas on November 25, 2013, 02:40:04 PM
Dear d3x0r
Thank you
I don't understand what's happening in the phtotos either :)
so on a joule theif normal, you have 2 common windings to power, 1 to the base and one to the collector/source.
to get high voltage, add another winding of a lot more turns than either prior winding.
lygeas
Quote from: d3x0r on November 25, 2013, 07:48:02 PM
Ok you have a point. \
I am uploading a schematic in order to clear this out. Please see attached photos.
I measure the output by substituting the led with a radial electrolitic capacitor 10mf 25v. This gives me almost 20v.
The 12v are when i measure from the led direct to the negative
