Automat seesaw...
Started by iacob alex, November 15, 2013, 12:45:55 PM
iacob alex
.....if we replace the two monkeys/ masses from :
http://www.123rf.com/photo_13268606_monkeys-planing-on-a-seesaw.html
.....with two masses , playing each one , on a separate belt arrangement (see yellow colour ), as seen at :
http://www.geocities.ws/iacob_alex/Some_Drafts/text036.jpg
      Al_ex
iacob alex
.....as a resembling first line image , using steam as its working fluid , you can see at :
  http://en.wikipedia.org/wiki/Steam_engine
  http://en.wikipedia.org/wiki/File:Grazebrook_Beam_Engine.jpg
Our problem can be to replace (fire+water=steam pressure ) with (continuous gravity unbalance+free fall=gravity "pressure") , in a simplified design (minimum number of spare parts ).
   Al_ex
Enstenow
iacob alex
     Hi !
Conceptually ,as a general idea , when you play seesaw (fulcrum,bar,two masses) , you apply the principle of variable / oscillatory leverage.
As you know , there are three classes of levers...the variable/oscillatory leverage , is alike...
Starting with this image , we can develop a variety of automat ("self") motion models , due to ("free falling") gravity unbalance...switching ,every half-turn ,the torque difference (gravity "push" ) on the same side of the fulcrum.
Enstenow , as I see , you have a proposal on this line...so , good luck for your test !
  Al_ex
iacob alex
.....is a non difficult evolution , development of a simple machine (lever) into a self-moving simple machine , due to inertia and the continuous gravity unbalance.
Thinking about the millions and millions of existing seesaws (fulcrum +first class lever ) , we can use them as "frames" and play variable leverage , if we add :
-a stable/fixed mass (fixed on the constant arm).
-a sliding mass(oscillating to and fro ) on the variable arm.
Variable/oscillatory leverage is a natural phenomenon ( motion of the celestial bodies/masses) , ...and so , becomes a common "intellectual property"...
Because "they" stated  the "impossibility" of this kind of motion /devices as "triple"...we can triple our designs (three kind of levers...variable/oscillatory leverage ) , also.
    Al_ex
