Reactive Generator Research for everyone to share
Started by gotoluc, November 15, 2013, 04:51:05 PM
JouleSeeker
For the record:
Quote from: gotoluc on November 15, 2013, 04:51:05 PM
Hi everyone,
today is my 52nd birthday and I've decided to share the most promising research I have found to date.
For quite some time I've been studying the effects of reactive power using all kinds of circuit configurations.
The circuit that seems to have the most promising results is a Transformer and capacitor combination.
At this time I'm using a Microwave Oven Transformer (aka MOT)
I'm sure there are even better suited transformers but of all the transformers I had on hand at this time a MOT is giving me the best results and I will share more on the details in the next post.
Don't assume this is common information, since it's not!... I have search the internet and youtube and no one has shared the results that I'm about to give. Also, I've been sharing my results with Gyula (in case I miss something) he is a well respected researcher.
He also could not find anything on the net of what I'm about to share. Gyula was also quite surprised of the results of the test as he thought the opposite would happen.
I'm sure this isn't a new discovery!... and most likely is the operating principle of many OU devices you have seen in videos or been hearing about.
However, those who have found this effect are not sharing and are probably of the same mindset as 99% of the world's population and think to make profit first rather than helping those how have much less than them
let alone thinking of helping our environment.
I have always promised myself to share all so here it is.
I only ask one thing from you and it's not difficult to do. If after viewing my video demonstration you see no value to what I share then please move on and don't bother wasting another minute of your time.
If you don't understand what is being shared! that's not a problem but I ask you stay in the background and keep looking at the updates and look at the posts of those who do understand and are willing to participate in developing this to its full potential.
In time it may come clear to you and possibly a list of the exact parts and where to buy them once a device is perfected.
If you can't build anything that's also not a problem as someone may offer a built device for you to buy. There's room for everyone but please lets keep this topic clean.
Also, please note,  I make no claims of OU... all I suggest is by using certain values of electrical components (which usually cause losses) adjusting and connecting them in a certain way, one could remove the Lenz effect on a load connected to a generator. Also, by using such a circuit on the input (prime mover) one could also reduce the input power by 50% (as demonstrated in my video) or up to 100% if you can develop a circuit that would make a better phase shift then my circuit used in test 1 video demo.
If this does not attract you please move on and don't waste your time watching this 30 minute video.
As far as I know this is the first ever video demonstration with an explanation of the benefits of a reactive power load on a generator.
Also, I'm not hiding anything in a box!  all is in the open and details given.
Link to video demo: http://www.youtube.com/watch?v=Guc8TADLteM
In the next post I'll include some more details on the effect of using a MOT and capacitors and include some scope shots of test 1 video.
Luc
Thanks, Luc, for sharing what you did!
tinman
Well i hope he finishes that house boat,as that was a realy interesting project to watch.
Wish you well Luc in your journey.
totoalas
Luc
thanks for opening the door ......   we can start from here .....  Romerouk has tested positively    .....
now back to work.....
nilrehob
Hi Luc,
I just saw Your new setup and I think its really cool!
Especially since I just got my hand on a MOT myself and have started scrambling for caps. Its in the air I think  ;)
Anyway, I just want to mention an interesting touch on this: imagine the voltage loss on a diode, no resistance but still voltage loss. To minimize the loss You work with higher voltage, right? The same goes with batteries when they charge, they are just like a diode with a voltage drop but no resistance! So creating any kind of HV LC-tank in resonance and a FWBR in series charging a battery seems to work great! Maybe the term would be reactive current?
https://www.youtube.com/watch?v=d3TsSD2l2ds
Next step for me personally is to duplicate/mimic Benitez patent nr 121561, please check it out http://www.tuks.nl/pdf/Patents/Benitez/GB121561A.pdf, its quite simple once You understand to skip the controller part at the top of the picture. It all boils down to the spark-gap creating HV HF which when in resonance and in series with a FWBR will charge a battery VERY efficiently. I think the spark-gap creating the HV HF resonance *ringing* may be where much of the magnification in Tesla's (and others) work resides. Please read the patent, I've never read a more explicit patent before. http://www.tuks.nl/pdf/Patents/Benitez/GB121561A.pdf
In this video I do a test with a sparc-gap and light-bulb (instead of a FWBR and a battery):
https://www.youtube.com/watch?v=P-HGbAr398Y
/Hob
PS: BTW, the RotoVerter uses resonance as well:
https://www.youtube.com/watch?v=TM4zlLS_94A
so resonance is a path well worth walking  :)
another PS: And Tesla was all about resonance too:
http://www.google.com/patents/US568178  :D
totoalas
Quote from: nilrehob on November 21, 2013, 02:30:19 AM
Hi Luc,
/Hob
Hi
Thanks for sharing
Hv and pulse  combined in a magnet locked stator  coil  retained a charge  that eliminated the use of rotor     and lit 40 w of lighting   with water tap connection
This set up  also kept ringing even without power supply
But most fascinating is from luc   that can make  multiple output
Cheers
Toto  alas
