Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
Hope
Well I guess I will be working alone on this project,  at least I am in good company.
NickZ
   Hope:
   Just what is it that you want to work on?  As there is not enough information, schematics, video build, or anything, to do something useful with the little information that Bashar has given.
                       Or is there?
   I am not looking to build a space ship, but an energy device that is self sustaining, instead. That can also produce a useable output. It does not have to fly anywhere.
   I feel that there can be a possible relation between the information for Bashar's type of engine design, and a self sustaining free energy device. As the extra input that provides for an engine to work may be similar in some ways to what it may take to make a self running generator produce it's own energy source.  As both need to extract any extra energy from the surrounding ambient.
Hope
Using a method to spin (smoke ring like) an energy field to make it focused and minimize losses.  Energy passing through the center of this emf smoke ring may find the center of the smoke ring superconductive and eddy's will not travel away but be focused to spin and provide a shell that contains the losses to a high efficiency.  I have been looking at Tesla's stuff and to me he was the master of using lines of force by using some method to create a friction-less (so to speak) method of energy movement.
He could also do this with standing waves.
Hope
It would stand to reason that any thing moving in a less restricted manor could travel faster.  Combining harmonics waves and standing wave back feed will give lines of force of any wavelength a path of lesser restriction.  There maybe a correlation between the gained speed and the energy mass.   Faster travel = more end force or kinetic energy for the same charge.   The harvest-able energy (sometimes called OU)  just maybe due to this gain.
NickZ
  Bashar mentions, that the ship engine has a center core from top to bottom of the craft.  And that around that center core spins a toroidal shaped energy field, with amplifier systems attached to this central core, to augment the original field to a higher output level. The top and bottom of the craft are dome shapes, joined in the middle.
  That is the relative shape, and idea, to help visualize what is further needed.
  So, a Bashar type of space craft (or generator device), should be build incorporating those physical properties, and ideas, to begin with.
