Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
Uniqorn
Quote from: WTF on January 17, 2014, 03:02:41 AM
@Uniquorn
Why do you think these wires should touch the rod when he doesn't say they should ever be in contact with it?
Because that is what Bashar SAYS to do: "...to touch in this way at a few points, at least four, THE GOLDEN ROD (that is) penetrating through the crystal sphere."
Not the crystal, but the golden rod, which in your case is a copper rod. Considering how vague the rest of the transcript is, this is the most clear part of it. The remaining exposed wires can touch the crystal or not, but as I mentioned earlier, the WHOLE mesh should be conductive, not just parts of it. This is why you don't need ALL the wires to touch.
You have the outside of the mesh exactly as it should be. The only unknowns here are: is the wire mesh dense enough (because Bashar does mention that it should be dense - "very tightly interwoven of gold thread,") and how close should the rims of the copper hemispheres be to the exposed outer tips of the wire mesh. For this, you will need to experiment.
So yes, you will have to drill at least four holes around the equator. They can be say 4mm in diameter to address your issue of the drill being to weak.
WTF
If when I get the clear crystal it doesn't work, I will try it your way, but the wires going into the crystal will have to be separate wires soldered on to the net, as the crystal is to close and the wires too rigid to do it any other way.
gauschor
Agreed, I think it doesn't help and you need to drill 4 holes. Maybe a 2mm diameter drill works as well, because 1mm is very critical.
Hope
Before you go and do any drilling on that found crystal let me research tonight on any other devices that might be using a quartz crystal to refine or filter signals.  It is an assumption I know about what is happening other than his clues in the latter part of the data.   I will look also at Tesla's known works and do a database search on what I can.   Will let you know anything I find.
WTF
@Hope
Thank you.
I also think why the wire net would need to be in contact with the rod when quartz is conductive to some extent. You put electricity through quartz and its shape changes. Bashar probably meant penetrating as a metaphor. Also what you need to remember is back from 1995 when apparently this video came from, Bashar spoke more alien like, when he called people from the audience he used to point and say male...........female, that's how he called people.
@Unigorn
Regarding the wire net, you said earlier that you think the wires should cross at every point to be electrical contact, I know the reason you said this is because only 4 wires need to touch the rod, but forgetting about the rod for one moment as at this point it doesn't make a difference if its touching the rod or crystal as its still 4 wires only touching something. When I read this part -
"Then at the outer boundary of the net, allow each wire to remain as a single wire, do not curve them back upon themselves, allow their ends to be exposed in the centre of what you would call the sandwich."
When he says allow each wire to remain a single wire that to me tells me that they must not come into contact with each other. Think of it this way if I had 2 wires and then soldered them together, wouldn't they become one wire. As at the moment they have their own path to follow.
I know sometimes people can see things other people can't see, and maybe you're seeing things I can't, but if you can please convince me they really should be in contact with each other, and why Basher has said they should be separated.
