How to make multiple Kicks
Started by Neo-X, November 23, 2013, 10:31:20 PM
forest
Bruce_TPU
I see only one weak point - manual switch. If you can show the same using mosfet or transistor like Otto did then thing may be easier to digest for those who don't believe.
P.S. a fish cannot feel the water pressure except when something is wrong with her swim bladder. Sure, fish generate a lot of bubbles but there is niuance only.The fish were told that is due to measurement error and getting more experience will fix that issue.Except when the fish meet with pistol shrimp.... :o
forest
Bruce_TPU
Quote from: forest on December 02, 2013, 04:39:12 AM
Bruce_TPU
Hi forest,
No weak point...you see, I dont care if "some" dont believe.   ;)  they never experiment anyway.
And I said to START with switching.   I am showing "proof of concept".  This is all Steven had when he started.
I am showing where I was months ago.  You all have to do your own experimenting.... sorry but just the way it is going to be.    :o
Forest:
Quotethen thing may be easier to digest for those who don't believe.
I assume that English is not your first language but using "believe" in the context of this discussion is a bad choice of words.  The sentence sounds like you are expected to believe something without any proof being given.  I have to have good proof and good experimental procedures and good documentation before I will consider believing anything that is out of the ordinary.
Bruce:
Whether or not I experiment has absolutely nothing to do with your proposition.  But I do know my stuff pretty well and so far you haven't presented anything that would suggest that your claims are true.  It's hard to even tell what you are doing.  I have given you some suggestions for improving your overall presentation and I hope you take them to heart and produce a much better clip next go round that includes a schematic and you also show all of the signals of interest with your scope.
To talk in riddles and drop hints and clues with no true verifiable substance is not confidence inspiring.  That could be taken from the script of any of a myriad of free energy scammers.  I don't believe that you are a scammer so why would you want to emulate them?  Please just be straight and say what you have to say and back it up with a well made YouTube clip.
Reiyuki
Quote from: MileHigh on December 02, 2013, 11:52:17 AM
Seriously MileHigh, it would have taken less time to do the experiment than than it took to write the previous wall-o-text.  Prioritize.
Anyway, for all concerned attached is the simplest Proof-of-Concept setup I could muster.  The alligator clip is just resting on top of the coil and not connected to anything.  I bet you would even get results manually switching with a multimeter and battery (Positive terminal only).
