How to make multiple Kicks
Started by Neo-X, November 23, 2013, 10:31:20 PM
Bruce_TPU
Quote from: cheappower2012 on December 03, 2013, 05:07:33 AM
Mark Dansie referred to SM as a conman that cheated Australian investors out of millions,
of course the investors were greedy,that was there down fall.
Here is SM in all hes glory showing 2 TPU's to some investors(suckers),the  guy talking to the investors after the demo is full of bull shit
and is another conman.
https://www.youtube.com/watch?v=W_fRKxz_UNo&feature=channel&list=UL
The inverter was a modified triplight inverter 12vdc to 110vac,keep in mind the year 1997,SM paid someone to do the modifing
,they changed the transformer  so it can accept 180 vdc ,it converts this to 110 vac.In my opinion SM is a liar, a conman and a crook,however the tpu is real.
Be careful with what judgment you judge another, for with that same measure shall be meted out to you...   ;)
The TPU IS real.  And Steven's clues have proven out to me and a few others..very real.   :)
Cheers,
Bruce
Bruce_TPU
Quote from: forest on December 03, 2013, 02:09:19 AM
That talk is useless. Please propose better method of measurement , some which would show without doubts Bruce has something unusual here or it's "just a noise". Now I know why there is only small exceprt on interation of vacuum bulb filaments with external magnetic field. There is more silly debates then it's worth so nobody can jump further...
Hi Forest,
Use a resistor...you'd be surprised.   ;)
Noise coupling in circuits:
http://www.youtube.com/watch?v=6uMjC8J3CLM
Capacitive coupling in circuits:
http://www.youtube.com/watch?v=GhdJKa6WOW8
Inductive coupling in circuits 1 of 2:
http://www.youtube.com/watch?v=yNBZZBfOBRA
Inductive coupling in circuits 2 of 2:
http://www.youtube.com/watch?v=l7Lw0BAHTIc
You learn a new thing every day.
Bruce_TPU
Wow Mile high, you can copy and paste YouTube video's....
This is NONE of your copy and pasted....
Accept it...  or not.
It is NOT a new phenomenon either.  Nothing "new" under the sun.
Hey I know...  You are "so good at electronics"...set up a on/off switch, a voltage source and hey, you don't trust magnetic pickups or coils, because they "must" be lying to you, then use a resistor.
And see for yourself.
I...WE on this forum already know that you won't...
One can ONLY wonder...Why NOT?
MeggerMan
Hi Bruce,
Think that SM could have faked nearly all the experiments using stripped down Cyclon batteries.
That is not to say I think he did - just that, I think, the battery tech was available then and it would have been fairly easy to pull off.
I am sure Cyclon batteries were around at the time as they were used by control line model planes that looped around a pole in the ground.
Hawker Energy
D cell 63mm x 34mm Dia. 2.5Ah
Output: 65A @1.5V =  ~97 watts (very high discharge current)
He could have used say 2 or 3 cells for a 100 watt supply.
[size=78%]If you look at the size of every toroidal shaped device it is nearly always 60mm in height.[/size]
So my thought is that he pulled each cell apart and partly un-rolled the spiral that makes up the cell and made them into a ring shape.
The using a long strip of transformer silicon steel (60mm width), 0.3mm thick, wound a thin toroidal transformer.
Using  the SG5124 or TL494 and a couple of mosfets, a reed switch and there you have it.
All this would have fitted in even the smallest device.
For the gyroscopic effect use a small motor and flywheel
The only demo I cannot explain is where he shows the device working at then cuts it into pieces with a jigsaw.
The open frame devices are shown to power lamps, that have heavy ceramic bases (probably containing a toroidal TPU).
You will notice he switches to a heavy toroidal device when powering the bulb in a simple small plastic base.
Has anyone tried to contact Mercury Marilla to see if he has further info?
He did say he still has the original tapes.
Meggerman
