How to make multiple Kicks
Started by Neo-X, November 23, 2013, 10:31:20 PM
Farmhand
Quote from: MileHigh on November 28, 2013, 12:35:09 AM
Here is some food for thought:
QuoteAccording to classical mechanics, I calculated that if an electron were to be accelerated through a potential difference of about 257 kV, it would breach the speed of light. Now, according to relativistic mechanics, this is obviously untrue. So, what are the mathematical corrections to be made whilst calculating the speed attained?
What I did was:
qV = (mv^2)/2 [Electrostatic potential energy = Kinetic energy]
How do I correct this using relativistic mechanics?
QuoteThe relativistic kinetic energy is (γ - 1) × m₀ × c², where γ is the Lorentz factor.
If you use that in your equation, 257 kV will accelerate an electron to 0.747 c. (And, for reference, a potential of ten times that - 2,570 kV - will accelerate an electron to 0.986 c. A hundred times that - 25,700 kV - to 0.9998 c. And a thousand times that - 257 MV - to 0.999998 c.)
So electrons moving at (close to) the speed of light don't come cheap!
I really like it when you guys get technical and explain it as you go a bit but leave some room for some brain work of our own.
Ta
Farmhand:
I was just mentioning that you can induce current with changing magnetic flux and yes that creates an electric field.  In fact it creates a circular electric field that the coil sits inside of and is more than happy to "pick up."  It's the same concept from multiple angles.  When you apply a voltage source to the coil, then the electric field associated with that voltage source snakes its way through the coil in circles.  Kind of the same deal one more time.
I think the simple summation of what I said that might make you happy is this:  What we call "displacement current" is the changing electric flux with respect to time through a closed loop.  It's also interesting in that you can think of the displacement in a physical form with respect to the capacitor dielectric, i.e.; the displacement in form that the stressed eggs undergo.
Bruce_TPU
Quote from: Farmhand on November 28, 2013, 12:18:21 AM
Bruce, if the kicks have energy than it took energy to produce them, saying otherwise is saying you can create work or energy from nothing.
Electrons do not scoot along wires at great speed like the charge does. Electrons hardly move much at all when a current is flowing and powering a load with very fast charge.
In my opinion the electrons only move a bit as they transfer charge to each other.
As I see it in an conductor with AC applied the electrons jiggle back and forth as charge is transferred between them with a net movement in relation to the energy consumed I think.
And I think in a conductor with DC applied they just jiggle a bit and move slowly along the wire in one direction as they pass charge to each other. The electrons certainly do not move as fast as the charge does in a conductor.  As far as I know or have been able to ascertain.
NOT created by nothing!!!   :o
Stevens whole point was to show that the Earths magnetic field DOES  have an influence on electrons! ::)
Power is neither created nor destroyed but tranformed.  Sheesh...really??
Bruce_TPU
Quote from: MileHigh on November 28, 2013, 12:59:16 AM
Farmhand:
Note you can also have changing magnetic flux though the coil to induce current flow also.
For the displacement current, since you know that the current is the same everywhere in a current loop, the easiest and most logical way to measure it is to measure real current somewhere else in the loop.  It really is as simple as that.
The two plates of a capacitor can act as the "glue" or "pipe" that allows the current to flow.  The metal plates can be charge neutral or hold an excess or lack of electrons.  So the AC current flow translates into charges flowing onto and off of the capacitor plates.  Think of a big rectangular baking pan as the capacitor plate and you pour a big glass of water into the center of the pan.  Voila, there is your current flow.  But there are actually two pans face to face filling and emptying of water, in a manner of speaking.
As to what is really going on, I am going to take a decent guess without looking anything up.  Between the capacitor plates you have a certain amount of electric flux.  The current flow translates into changing electric flux with respect to time.  So the "throbbing electric flux" is part and parcel of what's happening with the AC current flow.  If you could measure the changing electric flux with respect to time you would be measuring the current flow.
Even deeper, the answer is shockingly simple.  In the dielectric material between the capacitor plates, each molecule is like a little stressed egg shape.  There is an electric field present.  That pulls on the negative electron cloud and pushes on the positive nucleus.  That stresses and distorts the shape of the molecule so it looks like an egg instead of a sphere.  So that is a little mechanical spring.  You note that if the egg is stressed it produces its own electric field and that field is opposite to the applied field.  Hence with a high permittivity dielectric you have eggs that can really be stressed.  Also, you can't forget we are always talking AC, so the eggs are being stressed and relaxed over and over.
So, where is the current?  The capacitor is acting like a kind of transformer, and AC current stresses the eggs, throbbing molecules like so many stressed eggs.  The stronger the "spring" associated with a given molecule, the more energy you can store in the capacitor.
The kicks are NOT displacement current!!!
NO Dialectric show in video.  Raw metal ! :o
WRONG-  ding ding ding....try again!
Bruce_TPU
Ha!  If you think high voltage is the only way to accelerate electrons think again!   :o
Wrong- ding ding ding...try again!   ::)
Try not being a pc hero and do some real experimenting!   :o
