============= Simple Overunity Electricity ================
Started by FatBird, December 03, 2013, 08:08:00 PM
that-prophet
You use pulleys to multiply your rotations
And with electricity, more rotations is equal to more electricity
The massive multiplication of rotations is where we can gain the energy. The idea is to put power into the torque of rotating the large pulley of the DC drive motor, which is converted into massive amounts of rotations of the output generators, as we can connect tens if not hundreds of output generators through simply increasing the size of the belt that drives them to accommodate the increase in the number of small pulleys. The vast amount of multiplications of rotations gives you enough power to not only power itself, but cover any loss due to friction, and actually generate an excess of energy. The idea is, to use simple geometry(size change of diameters) to create an increase of rotations through massive circumferential differences. In effect, you are multiplying the power.
We don't need the air polluting effects of the combustion engine any more
We have self-generating electricity generators
That can be made to practically any size or voltage
So that we have the choice to have almost everything self powered
I know this will work, and I believe that this will change the world that we live in for the better. I proved that the idea works with my electric wheelchair experiment, but I have not been able to get a bicycle light generator to finish the prototype.(something I will be struggling to remedy for a while now) I also thought of using an electronics simulation software to not only prove that it works, but then we would have a video of how one actually works. I know, it`s so simple it seems too simple to work, and if it would work, then why wouldn't someone have thought it up earlier.
I know, it`s so simple it seems too stupid to work, and if it would work, then why wouldn't someone have thought it up earlier.
I figure that if you keep adding output generators to the belt
then you would eventually generate enough power
to make up for the power that you are putting into the drive motor
as well as any losses due to friction
until you add enough output generators
to have not only have a self powered machine
but you can get an excess of power as an output
= free energy output generator
Here are a few of the reasons for this system to work miracles
- The massive circumferential differences between a large drive rotor
o You put power into turning a motor only once-(lg)
§ When the power out generator(s) spin hundreds of times faster
· Each rotation gives you power to put back into the system
- Then you could add tens of these output generators
o All of these would be turning the many hundreds of times faster
- Them you could enlarge the drive motor pulley to the max
o As well as shrinking the size of the pulleys on the output generators
§ to make the multiplication factor even more
- So lets see, you are putting energy into the high torque motor with a large pulley
o And then through extreme size differences in pulleys
§ As well as the simple addition on 10`s if not 100`s of generators
· You get your many generators to spin many rotations
o That you are getting power out of
§ While your input motor only turns the once
· You have to make power
You need one DC motor as an input motor
Then you need at least one AC motor as a generator
This is one of the easiest way to multiply your input power
By adding additional output generators
on the same belt as your input DC motor with the one large pulley
Or, you could change size of the pulleys is another way to effect your multiplication
by shrinking diameter of output generator(s) pulley
or increasing diameter of DC input motor pulley
are other ways of increasing you multiplication
the drive motor and all of the generators could be any voltage
as long as they are of the same voltage
you might need to use voltage regulators
to keep this contraption running smoothly
Maybe this mechanism should be called an electricity multiplier
As you always need the initial amount of electrical power
To be multiplied into your gaining of free energy
Which can be initialized by giving the large pulley a turn by hand
this is a Miracle from God
yes, it does indeed work
using size change in diameters of pulleys
to multiply the rotations of your input motor
by the large change in circumferences of the pulleys
as in, the multiplication factor is due to
the tens if not hundreds of times the circumference changes
I just don't like the idea of somebody blowing up a battery
And maybe even catching fire
Now, most likely you will not be interested in this Spiritual part
But I discovered this by praying and asking the God of the Holy Bible
for a way to help us earthlings, the Tribulation Saints mostly
Especially during the 3.5 years of the Great Tribulation
Where they will need a way to survive our cold Canadian winters off the electricity grid
Don't believe in Satan or evil forces
Please explain why this simple idea
Of using change in size of pulleys to multiply electrical power
Has not been discovered all ready
to all Who are in the Family of Christ
this is for the tribulation saints
how else do they stay alive + hidden
in our cold Canadian winters
WARNING = the pre-Trib started on March 14th, 2012
http://doorschristmustpassthrough.yolasite.com/
joe lynch
one_christian_warrior@yahoo.ca
http://beliefstoliveby.yolasite.com/
QuoteI know, it`s so simple it seems too stupid to work, and if it would work, then why wouldn't someone have thought it up earlier.
Facepalm. Please don't have us do your homework for you.
http://peswiki.com/index.php/Directory:Motor-Generator_Self-Looped_with_Usable_Energy_Left_Over
QuoteI proved that the idea works with my electric wheelchair experiment.
No, you didn't.
QuotePlease explain why this simple idea
In the first place, as I have illustrated, there are Many Many prior "discoveries" of your idea. None of them work, because pulleys are just circular levers, and there is no energy gain in any lever system you can think of.
Also, because _power_ is not energy.
Work = Force x distance. Any pulley or lever system amplifies _force_ at the expense of _distance_ and does not increase the _work_ (that is, the energy) output of the system. In fact real pulley systems always introduce _drag_ and so the usable _work_ or energy output is always... ALWAYS... less than than the work (energy) input to the system. Nobody has ever demonstrated otherwise (honestly, that is.)
However, if you put a flywheel or other energy storage system (like climbing up a hill) in your device, then you can draw off more _power_ (peak) than you put in, for a brief time. Power is energy (or work) over a certain time. Watts = Joules PER second. If you expend that energy in a short time, you have high power. If you expend that same energy in a longer time, you have less power. Power is not energy (or work).
Please feel free to provide an actual demonstration, with measurements, that PROVES ME WRONG about any of the above.
Quotethis is for the tribulation saints
Now you are just being silly.
that_prophet
What this Christian Warrior is trying to get out to the world, is the simplicity of tHis Gift.
Free Energy is here + now, even free of all patent fees
= http://free_energy.yolasite.com/
or please Goggle free-energy + yolasie.
Please realize the dark conspiracy covering this subject,
yes this is dirt simple, almost too simple to work,,,
yet it does indeed work,
you just need the faith to try it.
Seriously, just try it out, and you will get to see the workings of one of His Miracles.
Please, don't let this miracle be hidden any longer.
Let us start using the technology of Ezekiel to change the world for the better.
Can I bring something of great interest + importance to your attention?
Free energy is the subject that I wish to bring up, and thoroughly discuss.
This is a subject that is not only of great importance to humanity,
but it will be a necessity for the Saints to use in the soon coming Great Tribulation.
It is also a subject that's greatly influenced by evil forces in our modern secular world.
we need a revival now
What this Christian Warrior is trying to get out, is the simplicity of tHis Gift.
= please Goggle free-energy + yolasite
yet it does indeed work, you just need the faith to try it.
Seriously, just try it out, +you will get to see the workings of one of tHis Miracles.
It's workings are super simple
You put power into a motor to drive a large pulley only once (little energy)
+ You get out a multiple of that electricity
Depending on how small the generator pulleys are
As well as how many generators with little pulleys attached
You simply must gain a multiple of energy
As you are only putting enough power into the drive motor to only rotate it the once
And you get back many times the electricity
Not only having smaller pulleys,
Gaining more rotations per foot of belt that you go through
To double or tripling your rotations by adding additional generators
To understand more where this warrior is coming from
Please goggle fire-starter + yolasite
Satan laughs at our gullibility, as he makes fun of this free energy device,
fooling all into believing that this is pure foolishness,
when reality is, it is super simple in its workings.
Physics state that the pulley system is used to multiply your rotations,
thereby multiplying your electricity.
It is truly that simple, and free energy could be being used
to remake all of our electric tools + toys with their own power supply
Evil forces are now, and have always been hard at work, covering up how simple this is.
+ think about how many jobs that it will create
modifying all of our electronics
to never have to pay for power to run them,,, ever
that_prophet
- in our modern secular world.
[/quote]
