Electric Motor Geenerator/alternator looped
Started by rice, December 06, 2013, 08:59:37 PM
lumen
This was a simple test to show that a gyro can generate a stable platform while consuming little energy to power itself.
The long term theory here is the possibility to supply centrifugal force, working only against the gyro's stability, to operate the gyro.
The concept would allow a single bearing point on a larger driving wheel as the only connection and would prevent any reverse interaction with the driving wheel.
Not a good description but in the end centrifugal force working against the gyro would power the gyro with 90% free excess energy.
lumen
Quote from: tim123 on January 13, 2014, 11:34:01 AM
Hi Lumen,
  that is a beautiful build... It's great to see actual research being done... :)
Are you working towards building one of your gyro-wheel things?
Thanks, The build took 1 day to dig for parts and design it and 2 days to build it.
I believe from the tests that it may be possible to build great force in inertial mass with little energy and that one only needs to use that force to achieve an over unity device.
It may be that a gyro is not even required to do the task but it appears to me the gyro test has shown the potential exists.
In my next build, I plan to skip ahead to a design that I hope can convert the force of inertial mass into useable output and do some testing on that.
tim123
Hi Lumen,
  I'm looking forward to the next installment.
FYI - came across this the other day (http://www.keelynet.com/interact/arc_1_98-7_98/00000297.htm)
Quote> All one needed to see was Laithwaite standing on a large weighing
> machine and doing his flywheel lift while one read the weight
> recorded. It was only years later that a television documentary on
> Laithwaite's gyroscopic activity, which included participation by the
> Alex Jones, was screened here in U.K. and it did include that weighing
> machine demonstration which proved the weight loss.
Could be an interesting experiment... :)
tim123
sarkeizen
Quote from: lumen on January 13, 2014, 01:08:14 PM
So again I'm not exactly sure what's going on.  Was there any evidence of this device actually providing any free energy?  Is there some model for this device which if you change a parameter you would expect free energy?
Also it, simply on casual inspection appears that everything that's happening in the device is happening because of the battery.  So what reason do we have to believe we can get more than a "battery's worth" of power out of this?  Put another way, where exactly do we think the excess power would come from, if not from the battery?
