Reactive power - Reactive Generator research from GotoLuc - discussion thread
Started by hartiberlin, December 12, 2013, 04:34:12 PM
hartiberlin
Thanks Luc,
2 points:
1.Please only use DC coupling for the scopeheads
2.Please zoom into the zero crossing of the waveform only in one half cycle and see,
if the Voltage and Current Waveform will change there, so the phase angle might only change
by a few degrees and this is the way to see it at the zero crossing...
Otherwise I moved the 2 threads into this new board and made Luc the moderator and
we want to make sure that this is no thread how to steal power from the power companies,
but to use oscillating reactive power to convert this to real power with no drag back effect and trying to loop
it this way. So all postings claiming we are only out here to steal power from the power
companies will be deleted. This is a pure research thread into this new phenomen.
Thanks for your attention.
Regards, Stefan.
Here2njoy
More on Resonance....  Tesla, Tuning and abundance
http://youtu.be/qpLBBaapbLU
Focus in on all the similarities that are now coming together.
Have you seen the new MRANGUSWANGUS video today?
ARE YOU  T U N I N G  IN?
gotoluc
Thank you Stefan
I have edited some post and deleted content that refer to Grid power.
As researchers we must be responsible for the information we write and share.
This topic title has always been " Reactive Generator research". It is about exploring the possibilities of using a Generator (alternator) output and connecting it to the circuit I have shared.
The circuit (if correctly tuned) will cause a 90 degrees phase shift (ideal conditions)
If the circuit is attached to the output of an alternator, it can output a certain amount of real power to a load and not cause the alternator to require additional power from its prime mover.
This is the only thing this topic is about and the only claim that I have made. So anyone saying I have claimed OU, Free Energy or Creating Energy and so on, I ask you to please show me the post I have done this and I will be more than happy to delete it and apologise for doing so.
I ask all to please stay focused on the topic and don't loose yourself in illusions. Their is no magic here! ... I may of used the word "magic" but I was being facetious. If this effect is what I understand it to be, then there is no magic, special energy to tap into, energy created and so on.
So all of you thinking along these lines will hopefully have a reality check soon as I think we will be able to come to understand it soon.
WARNING
If anyone uses the grid to power the circuit in question, please note that it is your responsibility to know the rules, laws and regulations of your country.
All who want to experiment with this circuit must use their own power source.
Also, the components, voltages and power used in this circuit can kill you if you don't understand what you are doing, make a bad connection or move your hand too close to the circuit.
Myself and this Forum will not be responsible for any damages, accidents or deaths.
I also recommend you don't replicate the circuit unless you are a trained Electronic or Electrical Engineer.
Any posts that are unrelated to the above research can be edited or deleted.
All the best to those who wish to experiment at their own risk
Luc
hartiberlin
Quote from: nilrehob on December 19, 2013, 06:54:10 AM
Three more videos on the subject:
Watt-Meter Resistive Load: http://www.youtube.com/watch?v=dxB9Rcs7Udw
Watt-Meter Reactive Load: http://www.youtube.com/watch?v=tnuusKhZzO4
Luc Reactive MOT Straight to Battery: http://www.youtube.com/watch?v=9LSTBMwC_lc
/Hob
Hi Hob, Well done !
But it seems your MOT transformer also has some flux guidance bridge  iron pieces, that distort the flux pathes, so that you get a nonlinear current waveform. You should look that up and remove them, so you get a linear transformer...
Regards, Stefan.
