Reactive power - Reactive Generator research from GotoLuc - discussion thread
Started by hartiberlin, December 12, 2013, 04:34:12 PM
d3x0r
Quote from: gotoluc on December 31, 2013, 01:41:01 AM
Hi everyone,
a researcher named Dog-One has been playing with the circuit with a Java Simulator and has made a video demo.
Link to video: http://vimeo.com/83003669
Luc
be nice if he included the link :)
but; the AC source is usually represented as negative power; but it turns out in reality it should be the absolute value of power... it's because the current is reversed... the AC voltage source (single terminal) always shows negative power...
QUick howto
http://www.falstad.com/circuit
Under circuits on the menu, you can select blank circuit at the bottom.
Right click on the black area to get a list of things to add... power/ac source is under 'input/outputs'
resistors are 'R' as a key, capacitors are 'C' as a key, wires are 'W' as a key.  (these don't work if you have a popup for editing parts)
right click on a part, and select edit to change the parameters.
after selecting the part, click and drag to add the part.
the part stays selected for just clicking and dragging to get a new part.
Space bar unselects any part, then you can click on a part to move it.
tinman
Quote from: gotoluc on December 30, 2013, 05:44:09 PM
So if you think a power generating station generators will see an extra load if I power my load at a power factor of zero can you or Farmhand then explain why when I connect the same load to my Generator (mini power generating station) the generators does NOT see an extra load.
Thanks for sharing
Luc
That is because your generator is already under load Luc-without your reactive circuit switched on.I am trying to find all the parts to put together a setup like your's,so as i can show you why there is no load placed on the generator when you activate the reactive circuit.I will then show you how much power you can actualy get from the generator without adding any excess load on the prime mover-you will be supprised,and i will show you were it is coming from.
ALVARO_CS
Hello Luc
I followed a lot your fantastic work at the joulethief thread. (made some succesful replicas)
here some spanish stuff about reactive power.
Unfortunately they have patents, and are looking for investors. the old story, but as they produce also other things, it doesn´t seem to be fake.
video demo:  http://www.youtube.com/watch?v=zUChl7zRzTA
Web page:  http://www.ortronic.com/ENGLISH/index.html
Cheers
http://www.keelynet.com/news/123013m.html
showing us a permanent magnet and the internal "static machine" process :
+ field and - field and : zero point ? no,alternating field-
                                                              pulsative displacement current
how would be the internal "static machine" process mosaic for a monopolar magnet, like a monopolar capacitor ?
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=10&ND=3&adjacent=true&locale=en_EP&FT=D&date=19770825&CC=DE&NR=2644927A1&KC=A1
Tesla " coil for electromagnet"
+ Hans-Dieter Goeres thermo-couple array electro magnet
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=17&ND=3&adjacent=true&locale=en_EP&FT=D&date=20071004&CC=DE&NR=102004020962A1&KC=A1
+ Wolfgang Klinsing refered Biot&Savart coil-formula
+ Henri Thrilles capacitor array
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19940318&CC=FR&NR=2695768A3&KC=A3
tinman
Quote from: gotoluc on December 29, 2013, 11:14:42 AM
To everyone,
the circuit is so simple that any experimenter should be able to check the effect them self.
For clear reasons you cannot use this circuit with an Inverter to get this effect, as Inverters are designed for typical circuits that short circuit electricity (kill dipole) and are not capable of re-circulating current and voltage.
The good news is, it works very well with an Alternator (generator) as demonstrated since day one.
All the best with your replication.
Please post your results and not your criticism
Luc
In regards to your circuit diagram with this post Luc,what do you mean by both hot sides with 240 volts?. We have 240 here in OZ,and the neutral is 0 volt's,while the active is 240v.
Anyway,i have gathered all the parts to replicate your generator setup,and will start building tomorrow. I will be useing a 24 volt 750 watt DC motor,so as accurate power consumptions can be taken.
