Reactive power - Reactive Generator research from GotoLuc - discussion thread
Started by hartiberlin, December 12, 2013, 04:34:12 PM
tim123
Crikey, that was like pulling hen's teeth... State secrets revealed at last eh, Luc... ;)
gotoluc
tim123
It's been educational, and better than TV... :)
I've been working on tank-circuits - for induction heating - which as you know contain 100% reactive power - with current & voltage 90 degrees out of phase.
If your circuit does indeed return more reactive power than it consumes - then would it not be possible to run it from a tank circuit?
You could use a ZVS driver, and a DC power source to give the initial power to the tank, and get it resonating.
If the circuit genuinely returns more than it consumes - then the circuit will power the tank with the returned reactive power - and you can disconnect the power supply...
gotoluc
Quote from: tim123 on December 31, 2013, 02:29:46 PM
I think a ZVS driver is not much different then an Inverter. Both are unable to use returned power.
These circuits were the first thing I tried back more than 2 years ago when I first shared this effect. As soon as I hooked it up to a pure sine wave inverter and it pulled watts I thought it didn't work and dropped it for 2 years. It's only 4 months ago when I decided to give it more tests and built the alternator that I understood what I had missed.
Luc
Luc
tim123
It's different from an inverter, but I think you should be able to drive a tank with an inverter and use it in your circuit too, in a similar way, and this is why:
- A tank-circuit is basically a container of reactive power.
- If you take real power out of the tank, it causes more real power to be drawn from the power supply to support the oscillation, and this is power-transfer in action, and clear to see (and hear - in my coils)...
- If your circuit creates reactive power - then instead of causing a drag on the tank - it should increase it's amplitude. The power supply should read less as the impedance increases...
- If your circuit uses real power - that will be shown too.
To use reactive power as real power - is logically and electrically equivalent to using a tank-circuit as the power source - but instead of it being diminished - it is reinforced by the load...
Unless you can run the circuit from a tank-circuit - without it causing a power draw - then I don't understand what it is you think the circuit offers...? If it's not OU - then what exactly is it all about?
