Charging battery from mains is series with a capacitor
Started by nilrehob, December 19, 2013, 10:51:19 AM
poynt99
Quote from: nilrehob on December 21, 2013, 10:36:55 AM
I'm sorry I missed Your post, my bad.
But Its not a down-step of the voltage, its a power-factor shifter and current-limiter.
/Hob
If you limit the current, then under load the voltage is going to be lower.
poynt99
In George Wiesman's own words from his doc:
QuoteThe CBC uses capacitors instead of a transformer to change highvoltage into low voltage.
poynt99
Hob,
Evidently your power meter can not be trusted.
So use your scope to measure the grid power. That means you'll need to insert a CSR and use a probe to measure the grid voltage and one to measure the grid current.
Then do similar by measuring the voltage across the FWBR (AC side) and combined with the CSR you can determine the power going into your charging circuitry. Then compare the two.
Are you willing/capable of doing this?
Let me know if you want me to draw it out for you.
nilrehob
Quote from: poynt99 on December 21, 2013, 10:56:13 AM
Hob,
Then do similar by measuring the voltage across the FWBR and combined with the CSR you can determine the power going into your charging circuitry. Then compare the two.
I'll do that (and more) but not right now, has to be when there are no guests in the house so I dont get distracted.
As a matter of fact I has to go now to attend to dear distractions ;-)
/Hob
