Negative frequencies
Started by nightlife, December 23, 2013, 12:27:31 AM
LibreEnergia
Quote from: nightlife on December 24, 2013, 10:19:03 PM
Stan talked about using the negative pulse. He may have been referring to the negative pulse as the part of the pulse that drops to zero but then again, he could be referring to it as the drop below zero and or the combination of both.
Alternatively Stan might have just been making up a pile of nonsense...
nightlife
Quote from: LibreEnergia on December 25, 2013, 01:53:21 AM
That is possible but it is said that he did create working curcuits that we have yet been able to duplicate.
nightlife
 Maybe they are referring to a negative frequency as the collasping wave of every wave with in a frequency.  We see all waves as a equal flow on both the positive and negative sides of the wave. Start to peak as being the positive and the peak to bottom as being the negative. When we utilize a wave, we are only utilizing the positive flow, the up tick, which is only 50% of the wave. If we could utilize the negative flow of the wave, the fall, we should be able to utilize 100% of the wave giving us twice the allowance to work with. Thats where negative capacitors would be helpfull. We could utilize the negative flow to create a positive flow and add it to the positive flow we now have creating a more powerful positive flow then we are able to have with our conventional ways we use now. Kind of like when we collect the collasping fields using Bidini curcuits.
Does that make any sense?
Dave45
When you talk about the negative aspect of a sine wave its just energy pulsing the other side of a coil not actually a negative as in a number sequence.
nightlife
 Are you sure of that? I disagree. You can not have a loss without a negative present. I dont care what is in question. I am talking about natural frequencies. If the flow falls from its peak, the fall has to be calculated as a negative.
