Bedini SG notes
Started by Channeler, January 02, 2014, 11:43:34 AM
Paul-R
Quote from: MileHigh on July 03, 2014, 10:07:41 PM
Farmhand:
MileHigh, if a patent like Bedini's is lodged and as it is claimed, he says it is based on Tesla's radiant energy arrangements then
shouldn't Bedini's patent cite Tesla's Patent as "Prior Art" ?
Farmhand:
It also suggests a conflict in citing something that is not actually in your own patent.  I think you caught him again.
i am pretty sure you can cite from another patent. He will be saying that he starts off from that point and develops it. It is the development that he can try to patent. But, as i said in the other thread, he has only seven years of patent protection left. He needs to get his a**e into gear pretty soon.
Farmhand
I think the main point of argument here should be -- When the Bedini SG switches a coil and discharges it to a battery is the effect  any
different to the effect obtained when the same coil is switched by a mosfet that is driven by an oscillator and the coil discharged into a battery.
I say no it is exactly the same effect.
A guy designed a pulse generator ( and posted it at EF) that was designed to connect to the base of the Bedini SG,
the idea was to get the SG running as it should (1 pulse per pass) then stop the wheel and connect the pulse generator to the SG
after first setting the pulse generator frequency to match the SG frequency then when the pulse generator is turned on the
SG operates just the same as when the wheel turns except the output is more. I built the pulse generator circuit and used it and
the waveform was slightly different (no hump) but charging was better and input was less.
I think only myself and another fella built it, and he tried to use his while the wheel was turning.  :D Got a good laugh out of that.
Shows the desire to be discerning is lacking.
Pirate88179
As I have stated in another topic, ALL of my 5 Bedini type motors only gave a "surface charge"  or "empty voltage" to the charging battery.  I started out with new bats and after a little while (no matter what the meters were showing me) the run bat could no longer run the motor.  This happened with 9 volt bats and 12 volt bats...it was all the same with all of my replications.  Everything always looked good, higher voltage going into the charging battery than from the run battery but, in the end, when you swapped them out more than a few times, the motor would no longer run at all.
After my experiments with the 2 new motorcycle bats (12 volt) which cost me like $50 each, I decided to use them for other experiments but learned that they would no longer charge up using my car battery charger and, when I returned them to where I had purchased them, they tested them and said they were both "shot".
This again is my own experience and you can watch my videos at youtube by looking at Piratelabs.
Farmhand
Here you go MileHigh, I found this animation. What do you think of this one ? It's been up on you tube for years.
Understanding the Bedini Circuit by introvertebrate
https://www.youtube.com/watch?v=yi7cmUpMdX8
Pirate88179
Quote from: Farmhand on July 04, 2014, 06:36:48 PM
I used this guys videos and schematics to build my first SSG.  He gave very detailed information and, I noticed that he went on to build more advanced motors but then....quit doing so.  Possibly he learned what I had learned?
