Joule theif : try out !
Started by omdano, January 06, 2014, 07:35:30 AM
omdano
So.. i measured the voltage straight out of my peltier .. it is about 0.1 volts .. It seems that i have underestimated my peltier .. so... is there any way i can boost it ?
(i can use 2 peltiers :p)
So.. a schematic will be Wonderful
xee2
Quote from: omdano on January 08, 2014, 04:59:40 AM
Yes, you can put peltier units in series to get higher voltage. I have not tried the 25 mv circuit in video, but that may be your best option.
infringer
Have you tried fixing them to your window to see what you can get out of them top end that is if you live in a cold area...
That should be the biggest temp difference in your home.
Anyhow good luck with your project I would suggest getting like 10 of these and trying to run a light that way you should have a safe voltage then...
But I will tell you that they do make indoor solar cells that can absorb solar from your indoor lighting to charge a battery this is another option depending on which direction you are willing to go...
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
omdano
I have searched in the 25mv thread for a schematic but didnt find one , if anybody gets the luck help me and post it here :p
omdano
So... As in this circuit :http://www.youtube.com/watch?v=XQ7dua2mBzo
i can replace them with any germanium transistor or is there any specific types ?
Can i get the transistors that work with such a circuit so i can buy them ?
thanks very very very much
