Small amount of HHO Gas into automotive Catalytic converter yields OU heat??
Started by ramset, January 14, 2014, 07:25:58 PM
The Boss
Quote from: woopy on January 26, 2014, 01:27:17 PM
Hi all
just made a lot of test today.
The best result seems to happen on the flat surfaces (i cut the honeycomb in the longitudinal direction, so i get some flat surface)
Woopy,
You may want to consider testing with one of these:
http://www.amazon.com/Minicat-Sensor-Spacer-Adapter-Extender/dp/B00CBKEC06
conradelektro
Than i tried to inject moisture in the cat honeycomb, and than i could not get the reaction on the wet portion. So i think it will not work with my vapor from my LENR reactor. But who knows ??
May be you can let your vapour filter through some silica gel
http://www.ebay.fr/itm/400g-BAG-SILICA-GEL-SELF-INDICATING-FOR-GENERAL-USE-/281240594732?pt=UK_Packaging_Materials&hash=item417b3ee92c
After some time the silica gel will be too moist, but you can dry the silica gel in your oven.
methods for reconditioning silica gel - Art Preservation Services
Greetings, Conrad
tim123
Hi Woopy,
  thanks for the vids - very interesting and entertaining :)
You could send the output of your cell through a water bubbler - to remove the droplets...
If we could separate the O2 and H2, and bubble them into two platinum electrodes - we'd have a fuel cell with electrical output...
How to make a simple hydrogen fuel-cell:
http://sci-toys.com/scitoys/scitoys/echem/fuel_cell/fuel_cell.html
Magluvin
Catalytic material has platinum or paladium which works a a substitute for platinum, and what it looks like is happening is the cat material seems to be able to act as a shorted fuel cell producing heat instead of electrical output.  ???
Is the cat material dripping water, or is it evaporated instantly due to heat of the reaction?
Nice work Woopy ;)
Mags
conradelektro
