Lenzless resonant transformer
Started by Jack Noskills, January 17, 2014, 04:58:15 AM
Jack Noskills
If parallel LC-circuit blocks certain frequency, does it mean that core is saturated when this resonance occurs ?
If not, then L3 needs to be done so that it blocks current flow at the secondary resonance frequency and only then capacitor can be used to for matching resonance in L3. This is how I obtained turns to use in L3, had resonance in L3 only once though.
verpies
Quote from: Jack Noskills on March 03, 2014, 02:51:55 AM
No, but if saturation does happen then it will increase this resonance frequency.
verpies
Quote from: itsu on February 26, 2014, 03:45:11 AM
Quote from: verpies on February 25, 2014, 03:47:15 PM
The theory/idea behind this is in this patent.
Hmmmm,   a "solid state electric generator" he,  sounds interesting.  Seems that jack has already the main ingredients.
Square wave in, (in resonance), sine wave out?
Regards Itsu
Yes, but it can also be a saw/triangle/sine wave in, sine wave out, because the primary LC tank will create a sine wave out of anything at the input of this generator anyway.
The whole Gunderson generator can be put into a large pot-core in order to close the magnetic flux paths as illustrated below.
itsu
Quote from: verpies on March 03, 2014, 12:56:39 PM
Thanks, nice drawings, but looking at the size of the pot-core, this will be miniature / precision work.
Regards Itsu
itsu
Quote from: Jack Noskills on March 03, 2014, 02:03:32 AM
The whole idea here is to create two opposing magnetic currents/fluxes/'what ever you think there occurs in the core when coil is energized', which then amplify each other.
"amplify each other", well normally you need input for something to amplify, so i am still not sure how this should work.
Anyway, i finished the 3 coil setup on the nanoperm core, any suggestions on how/what to connect to fullfill the above situation?
Video here:   https://www.youtube.com/watch?v=GbqDckFNtSg&feature=youtu.be
Regards Itsu
