Lenzless resonant transformer
Started by Jack Noskills, January 17, 2014, 04:58:15 AM
Jack Noskills
Thanks for your efforts Itsu.
Can you estimate what was the input power to L3 after the audio transformer as this is what comes in the system ?
If the load was disconnected your power amp still used lots of power due to impedance mismatch ?
I wonder what is the difference with your power amp compared to mine ? I don't have to use anything special after the amplifier. When I placed the L3 with nanoperm it blocked all current flow nicely above 10 kHz and my grid watt meter did never show more than 7 watts. Well, meter is not very good, it can measure accurately only loads above 5 watts.  Also I did not notice anything special when connecting more load in the output, no need to retune it as it was just more resistive load. If the output lamp is not bright then current flow is not high and in this case those L2s cannot feed each other very well because there are no amps circulating in them. And amps are needed to magnetize the core. So best way to fail is to use low input power :-) Now that there were some amps in the L3 then output light was bright. Unfortunately amount of power in L3 is unknown.
Impulse response of the system would have been nice to see though. I put here a link to your video how to tune this in case someone else is interested in trying:
https://www.youtube.com/watch?v=BE7tAbYRg7w&feature=youtu.be
verpies
itsu
Quote from: Jack Noskills on March 11, 2014, 08:07:24 AM
Thanks for your understanding.
I made a last measurement with the same setup as in the last video and setup the power into the bulb to exactly measure 1W (500mW * 2).
Then i measured the input voltage across the L3 with the blue probe and measured the current there, see the picture for the outcome.
We have 581mW * 2 = 1.162W into the core/coil.
The PA is an XT800.2  automotiv MOSFET amplifier class AB at max. 50KHz.
Regards Itsu
itsu
Quote from: verpies on March 11, 2014, 02:23:40 PM
Gunderson patents?
Might be i good idea, i see you already found a thread for it here:
http://www.overunity.com/1297/graham-gundersons-dragless-generator-patent-lenz-law-violation/msg324252/#msg324252
According to Jack the drilling in the nanoperm should be no problem; good drill bit (diamond? or for ceramic tiles?) low speed and low pressure.
Regards Itsu
verpies
Quote from: itsu on March 11, 2014, 04:04:16 PM
I was not writing about any particular one.  Gunderson patented two devices: Device 1 and Device 2.
IMO it is advantageous to keep magnetic flux paths closed in both of these devices.
P.S.
The first device seems to be related to the Davidson patent .
