Free energy device Romania
Started by xhacks, January 24, 2014, 06:38:25 AM
xhacks
You can check them here e2matrix: http://www.youtube.com/user/marinescuadrian1999/videos
When I will raise my money I will buy an oscilloscope, and I will let you read the measurments...
Till then I will try to remove the battery and add a huge capacitor to check if can self loop, without a battery...
penno64
Adrian,
That is wonderful.
Will you be sharing schematic and coil details ?
Regards, Penno
xhacks
Quote from: penno64 on January 25, 2014, 02:45:07 AM
Adrian,
That is wonderful.
Regards, Penno
THE SCHEMATIC IS ATTACHED!!!
penno64
Thanks Adrian, I had previously downloaded the schematic but whilst I can determine what most components are, I am having problems with others.
Lets see -
TL494 set for 50Hz and 50% duty cycle.
T1 & T2 are both 2n3055.
12v Battery to the right side of diagram via 4700uf capacitor.
Feedback from L5 via 75w bulb into 220 -> 12v transformer through bridge then 4700uf and up to feed 2 x 2200uf buffer caps.
L1 & L2 unsure ?  maybe ?024,0  turn and .01mm
L4 & L3 ?????? 500 turn 00.3 mm
Ground (earth) via centre of main coil.
Left bottom corner -
T3 & T4 are both tk805 driving a TBC (flyback) then into I think a high voltage Bridge rectifier via a 100k and spark gap
On DC side into 470uF HV cap I think ?
I then think another adjustable spark gap then into L3. Uncertain what is written next to L3 with arrow pointing to it.
Same for arrow pointing to core.
What are K1 and K2
Well, how did I go.
xhacks
K1 and K2 are relays, and switches
Cheers,
Adrian
