Elastic rope
Started by Gabriele, January 26, 2014, 09:01:59 AM
Gabriele
Could it work? Pressure in 2 containers isn't equal cause on the top the elastic acts on less surface of pistons with the same force respect lower...
LibreEnergia
Even if there is an imbalance of forces initially, all that will happen is the pistons will move until the pressure is equal on both cylinders, at which point movement stops.
You then have to reset the pistons to the initial position. That will take the same  of energy (or more due to losses) as was released by the initial movement.
