Wasif Kahloon's Magnet Motor
Started by NTesla, January 29, 2014, 12:31:49 AM
DilJalaay
Quote from: hartiberlin on February 03, 2014, 10:34:11 PM
What I already wrote on Facebook:
Yes, Wasif, the problem is we have had  over the years many fakes, like the Mylow story, the Perendev scam and the Yildiz guy not coming forward and hiding the inner working of his motor and having cables coming out there, etc..
so Open Sourcing would be great and probably the only solution to a widespread acceptance in the conservative science community ...
What still concerns me is the fact, that when he put the clamp around the stator magnets and thus reduced again the distance of the stators versus the rotors, the motor speed did not change or drop...
I still believe the generator might still be a motor and just drives the Perendev style unit and that there are hidden batteries somewhere inside the double wood boards....we need to see the motor alone spin up  for at least a few seconds !
Come on, if the Perendev style motor is really working, you could easily show it without the "generator" by just controlling the stators with your hands and just show for a few seconds, how the rotor will selfaccelerate, when you press the stators together...
Also in the first Video I hear a hum noise which is simular to the noise a starting motor makes...so I think the generator is really a motor being powered by a hidden source..
Dear Sir,
I talk to him he is not engineer, he is lawyer and a property dealer.
He said that there are some group of people behind this.
[size=78%]So i think he cant give us reasonable answers.[/size]
[size=78%]
[/size]
Also he told me he is going to opensource also no need for money.
I requested him to visit him,he refuse and told me that he has no time to show me his device.
What i am worry is, if he want to opensource as he said, why is making alot of bublicity?
Regards,
D.J
MarkE
Quote from: DilJalaay on February 03, 2014, 10:42:46 PM
Dear Sir,
[size=78%]
[/size]
Regards,
D.J
That's funny because Wasif is all over the net asking people to visit him.  What you should be worried about is that the device is an obvious fake.
deanc5000
Careful asking Wasif to run the magnet motor alone without the generator. I believe he can do that, but not without a hidden ac feed from the mains. From the audible hum in the first video, we know he is using a 220V 50hz ac motor to drive the device. I am pretty sure the ac motor is hidden in the front section of the fake magnet motor and the generator is totally hollow. My reasoning is that no torque whatsoever is ever being transmitted through the spring coupling (except to a short fake front generator shaft that only weighs a few ounces). So if he removes the coupling, the mag motor will still appear to spin by itself.  Just sayin up front in case he has the audacity to play that card.
Jimboot
I'm not making a statement to fake or real either way as I'm not qualified but "we know he is using a 220V 50hz [color=rgb(27, 142, 222) !important]ac motor[/color] to drive the device. "  is a step too far.
SUrely crying fake without proof is the same as crying real without proof.
For instance his mum may have switched on the washing machine just out of shot hence the AC hum. :)
MarkE
Quote from: Jimboot on February 04, 2014, 12:22:38 AM
Jim, we know that Wasif is lying from the simple observation that there is no perceptible reaction torque from the device he claims is a generator that produces 3kW at 80rpm, while connected to ~3kW of load.  Were the device actually what he claimed, it would require over 250 lb ft of torque to turn the shaft.  In both videos we see that the "generator" instead turns freely with just a gentle push.  In the second video we see that the "motor" and the "generator" are coupled with a poorly aligned and soft compression spring with only a common hose clamp retaining it on the "motor" side and no visible means of attachment on the "generator" side.  Yet, according to Wasif's claims that spring would have to transmit 250 lb ft of torque.  And as Dean has pointed out, the "generator" is missing the end bearing on the load side.
Wasif has revealed far more than enough to determine without any doubt that the machine is a very bad fake.
