Wasif Kahloon's Magnet Motor
Started by NTesla, January 29, 2014, 12:31:49 AM
Hoppy
Quote from: T-1000 on February 03, 2014, 07:40:47 PM
"keep it stupidly simple" - if you would have self running magnetic motor, no electrical parts are needed for a proof as mechanical measurements are enough ;)
Yes, that's exactly what it is - simply stupid.  ;D
Hoppy
Quote from: deanc5000 on February 03, 2014, 11:52:38 PM
Careful asking Wasif to run the magnet motor alone without the generator. I believe he can do that, but not without a hidden ac feed from the mains. From the audible hum in the first video, we know he is using a 220V 50hz ac motor to drive the device. I am pretty sure the ac motor is hidden in the front section of the fake magnet motor and the generator is totally hollow. My reasoning is that no torque whatsoever is ever being transmitted through the spring coupling  (except to a short fake front generator shaft that only weighs a few ounces). So if he removes the coupling, the mag motor will still appear to spin by itself.  Just sayin up front in case he has the audacity to play that card.
Agreed. Its very likely that the magnet motor is powered by a small built-in motor. However, the nails would still be needed unless he can come up with another way of supplying power to the motor. As there would no longer be a lamp load to power, he could use very thin insulated wire / ECW which would be difficult to detect on video. Better still, he might even be able to conceal a thin Lipo pack and small inverter in a cavity within the laminated timber base, so its quite possible that we will see another attempt from him. It will at least be guaranteed to increase his overall hit count!
AnandAadhar
Funny indeed. A magnet motor without magnets.
There are a lot of empty holes in the setup, stator clamps and rotor, just a few seem to be filled at random.
And I'm not even sure about that.
Poorly drilled too these holes.
Cannot work that way.
Anand Aadhar free energy research pages: http://theorderoftime.com/science/free_energy/index.html
Hoppy
Quote from: AnandAadhar on February 04, 2014, 06:18:03 AM
Indeed. It looks to me like a discarded experimental setup that likely never worked, thus providing the incentive to fake a self-runner.  :(
The method of powering is interesting as this is along the lines that I think Kapanadze used to power his 'Green Box' device. In Kapanadze's case, the 'hot' wire is probably buried and instead of nailing into it, the bearded guy uses a magnetic coupling between the heel of his shoe and an exposed end of the wire.
Pirate88179
Geeze, this sounds worse than Mylow.
