Square Wave using 25Mhz Crystal oscillator
Started by TheOne, January 30, 2014, 10:42:00 PM
TheOne
Ok after reading and reading, not sure if the signal gen will keep the last know setting when off, but I realized that I have some PIC microchip lying in a desk, I can make my own signal generator like I want http://www.engineersgarage.com/electronic-components/pic18f4550-microcontroller
Let say I made one, I just need square wave, duty cycle 50% but also adding a little deadtime. LCD support seam easy too http://electrosome.com/interfacing-lcd-with-pic-microcontroller-hi-tech-c/
So I just need to be able to change the frequency/period/dead time and save it once changed
I will have full control this way, coding is not an issue for me since I do that as a living (software)
So the controller will be used for managing the LCD and frequency with 2 pin used for the square wave, should be easy to do, I dont know why I did not think about it!
TheOne
Here one PDF relative to magnetite frequency
http://link.springer.com/article/10.1007%2FBF03157336#page-1
For those who are interested on magnetite
Turbo
Quote from: TheOne on February 02, 2014, 09:45:24 PM
just use the HPWM command it makes use of hardware PWM you can set the freq, duty, etc in the software real easy.
or just go with high low and pause and lcd is easy too but only when you need a readout if you just need the signal you can set it by in circuit programming and off you go.
TheOne
My old PIC controller was not working with my Windows 8. I ordered a new programmer PICKIT3 which is working quite well.
Here some shot of my current controller (OPENMEG Controller)
You can adjust the frequency, duty cycle and dead time, values are saved in EEPROM memory so even
if the controller is off, the value are restored when on.
Here some shot of my messy breadboard :)
I need to test the PWM, even if its coded, I need to test to see if that work correctly, but so far I am happy of what I have done in 4 nights including interfacing with the LCD.
