Beam gravity engine...
Started by iacob alex, February 04, 2014, 05:44:17 AM
DreamThinkBuild
Hi Burnit0017,
Nice build, it's similar to M. Kanarev's work.
Attached is a possible way to maybe extract power from it. The tricky part is getting power from the system the load will have to be evenly distributed between the two generators or they will unbalance each other.
iacob alex
.....is the particularly proposed name of this topic.Here we can have three questions :
    -where is the beam or something alike?
    -how plays the gravity ?
    -what is the primary design/principle of this possible kind of engine ( converting gravity potential energy into mechanical motion) ?
  So , we are "beaming" ,following like a radio beam, as an aircraft ...to gravity or to variable rotational inertia ?
     All is basic mechanics , nothing more...in my opinion.
         Al_ex
burnit0017
Hi, thank you to everyone for the added info. I plan to add a drive gear to the support arm to drive a PMA with a MPPT circuit at the output. I will use a double pendulum with electromagnets to oscillate the crank. I am fabricating the support frame now and will post results when available. Thanks again.
telecom
Quote from: iacob alex on August 24, 2014, 03:59:21 PM
         Al_ex
Perhaps it can be like this:
1. have a massive balanced beam
2. make it unbalanced with a tiny weight
3. make other end to accelerate to a considerable speed
4. transfer a momentum to a generator
A tiny weight on one end will create a huge momentum on another end(m x v)
ARMCORTEX
the device of feliz wuirth, living machine.
does not work, it does not even have a tappable shaft from what I can see.
The Device of Kanarev, unworkable, it needs impossible clutch.
a device wich is basicly the reference in terms of gravity devices was the chas Campbell
from my research, was a legitimate device.
http://www.overunity.com/12464/using-chas-cambel-flywheel-system-for-15-horsepower/135/#.U_qAU010y70
From the sims i did, if we add a small, hidden, eccentric, we can have rocking motion wich is = to rotating frequency, if the frame holding this rotating mass is somewhat loose.
It is my belief, that this switch flywheel is trapped between loose( pulleys) , wich allow it to oscillate by translation just enough to be energized by drive motor and squeeze the the pulley powerfully and fast, avoiding connection of input to ''filter wheels'' if possible When such force of applied tangantially at 1000hz, the lead out theory happens.
I believe that this attempt is quite obvious with chas first video, but that others, are batter @ hiding this oscillating tension on the belt.
The Turkish company is a perfect example, you cannot visually notice the rocking. but their assembly indicates to me that their tensionner needs to be tuned.
