Beam gravity engine...
Started by iacob alex, February 04, 2014, 05:44:17 AM
iacob alex
     Hi 0017 !
This thread was intended about a possible gravity powered device ( see the main topic...) , if we start with a fulcrum , a beam (lever) and a certain arrangement of two masses , so to play variable/oscillatory leverage due a continuous gravity unbalance , on the same side of the fulcrum , nothing more.
As I see , you test a personal mechanical contrivance (as  Felix Wurth and others...) ,aiming to manage some centrifugal effects for ...?!...maybe to deal with a controllable tractive vector ...so to use it for...?!
One of the secrets of the life , is to keep our curiosity alive...so , I wish your success !
     Al_ex
burnit0017
Hi, thanks the for info, I will start a new thread. Thank you for the help. Cheers
iacob alex
.....as a manner to simplify our imaginative attempts for a gravity ( "self") powered device , at :
            www.youtube.com/watch?v=Upp-Xr5JAg0  (Remzi Eyupoglu)
Somebody ("veproject 1") made a test at :  www.youtube.com/watch?v=c9YLkoJz7rM
...working/rotating for a while , due to a starting push.
They play a beam/lever , with two equal masses/equal arms ( a centered body ) and a pendulum ( an eccentered body ).
Easy to make a simple "cut" of the up-here design and to test it...if we play two masses /pendulums /eccenters, only on the beam.
It does seem that , due to a continuous gravity unbalance , on the same side of the lever's  ffulcrum.....it's  a "different" game
           Al_ex
iacob alex
.....if we replace the steam power concept , from :
www.john-tom.com/ElmersEngines/WebElmers3D/Web_09_TWIN%20CYLINDER.JPG
...with the gravity unbalance ( a Class 2,3 oscillatory leverage ) , of two beams , at :
www.geocities.ws/iacob_alex/Some_Drafts/text032.jpg
        Al_ex
Low-Q
Quote from: burnit0017 on September 14, 2014, 06:26:25 PM
Hi, making progress. I still have to install double bob pendulum. Using overrun clutch to drive main flywheel. If you want me to start a new thread please let me know. I think the problem with the design you posted is it will find equilibrium and stop.
For your information:
All types of machines like this or other which is suppose to work without input, will find equilibrium and stop.
Also, feedback loops or assistance of any kind needs energy to be taken from somewhere. Taken from the machine itself will likely cause the feedback source to be fed by the machine itself. How do you in a closed loop determine where the energy source, feed backs, or assistance is coming from? Can you determine in what "direction" the energy is flowing in a closed system with no energy input?
Vidar
