0 Members and 35 Guests are viewing this topic.
Quote from: mrwayne on March 23, 2014, 09:18:46 AM
More   8) 8) 8) 8) I did not claim that Gravity is non conservative... You twisted our claim.
What is claimed - and missed or just  8) 8) 8) - is that we have designed a "mechanical" device that circumvents the conservative field of gravity.
Big difference - Which has enabled us the ability to utilize Gravity as an energy source.
What you claimed and are continuing to claim, hypocrite liar Travis, is this:
QuoteOur Technology produces clean energy Mechanically, by altering the once believed conservative field of gravity - allowing us to supply endless and abundant clean Energy.  Many have tried!  It is our humble privilege to say that "at Zydro Energy we have exceeded the impossible".
What part of "ALTERING THE ONCE BELIEVED CONSERVATIVE FIELD OF GRAVITY" is unclear to you?
You are saying that you are "PRODUCING ENERGY." You are saying that you are altering the field of gravity. You are saying that the field of gravity was once believed to be conservative... but no more, because of your mechanical technology. You are saying that you have "EXCEEDED THE IMPOSSIBLE." You are saying that you can "SUPPLY BOUNDLESS AND CLEAN ENERGY".
Big difference all right... since you can actually do NONE of that. You can't even power a simple water pump with your "technology"! You're all wet! And soon you'll be underwater.
Simply changing your outrageous claims to make them into future "expectations" and "visions for the future" does not remove them from being fraudulent claims.
minnie
   In the shop where I get hydraulic pipes made, behind the counter there's a sign.
   It says "Impossibilities take about an hour, miracles take considerably longer".
    I think mrwayne's into the "need a miracle" category now.
                       John.
MarkE
Quote from: webby1 on March 23, 2014, 08:38:35 AM
Are you saying:
A: that the pizza pan needs to be full of water AND you need to push down with 1.905mJ, so that is 1.901mJ worth of water on the pan AND 1.905mJ added to force the risers back down from state 3 to state 2.
B: That after you apply 1.905mJ to push to  the risers down you then must apply 1.901mJ to move the water into the pizza pan.
What is tragic here is that the fraud Wayne Travis holds you up as an expert and you present yourself as incapable of understanding the transfer function of a simple compression spring, or in this case the same transfer function performed by the Nested Russian Dolls of Ignorance.  Apparently this stuff is above your pay grade.
MarkE
Quote from: webby1 on March 23, 2014, 08:48:42 AM
The slower one is willing to go?  that means rate and when does rate have anything to do with energy???
It is not how fast, is it,, that would be power and power is not energy.
The SLOWER one is willing to go,,,
The faster you want the machine to operate the less efficient it becomes.  Try to keep up.
MarkE
Quote from: webby1 on March 23, 2014, 09:03:21 AM
Just to be clear here,, you are saying that energy is not f*ds or E=maDon't like what is said so you make fun of it,, interestingNope! the weight of some water shifted into vertical columns,, not the same thing really
So you think energy is a real thing,, that is a shame because it is not.  Energy describes a real relationship,, but energy is and for ever has been man made,, non-real.
The force is not important when it is moved over some distance???  That's right, you do not think that force and distanced moved is what is called, energy.
I have stated many, many times that energy is the integral of F*ds  As a representative of what Wayne Travis calls as an expert, your presented inability to comprehend basic concepts does not bode well for the caliber of help Wayne has hired.
