MarkE
Quote from: webby1 on April 15, 2014, 04:53:10 PM
This is why I am asking on the riser weight energy part.
If I do not take it out of the input and use the full return then energy has left the building, and with no friction or lost water or air,, where did it go,, plus no heat.
st2estoredtotal                 0.0055107459J
st1estoredtotal                  0.0034123194J
st3estoredtoatal                 0.0036144798J
st2input                             0.0020984266J
ideal output                        0.0016509930J
Riser weight energy            0.0002452732J
Change in riser GPE ST2 => ST3
st1 to st3 return energy       0.0002021604J
Is it?  Assumptions!
Input minus Riser weight     0.0018531534J
Why would you calculate this value?  The input energy required to go from ST1 => ST2 is unaffected by the riser weight Mondrasek has added.
Output plus return               0.0018531534J
Your getting closer, but no cigar.
So using everything in an ideal setup takes the system back to its starting energy level,, and is that not a required condition?
minnie
  Am I getting it with my ideal see-saw?
  My see-saw has an equal weight on each side.
  It just sits there, motionless.
  I add a bit of extra weight to one side, the speed depends
  on how much extra weight I use.
  Now one side descends and hits a stop at the low point.
  To get it to move again I have to either remove the extra weight
  from the low side and put it on the high side or put more weight
  on the high side which is sufficient to make it move and overcome
  the extra bit I originally put on.
                    John.
camelherder49
When water is about to fall over a dam there is no acceleration without gravity.
MarkE
Quote from: powercat on April 15, 2014, 05:16:53 PM
A couple of classic quotes, and some new ones showing how things have progressed to the current situation
Quote from: mrwayne on May 25, 2012, 04:14:10 PM
I promise, you who wish open sourcing will not be disappointed.
Quote from: mrwayne on March 30, 2014, 02:28:17 PM
The Zydro Energy expands the understanding of science - and shows that a mechanical super conservative device can be built.
Quote from: mrwayne on March 29, 2014, 06:35:37 PM
So what have we been doing for four years........ you will know soon enough.
Quote from: mrwayne on April 08, 2014, 04:32:45 PM
We will not be publicizing our test results until the Public release of our Manufactured models - which are currently scheduled to roll out in October 2015.
Quote from: mrwayne on March 31, 2014, 03:57:19 PM
Third - It is maturity - and the understanding that Super Conservative Net Energy Systems do not require OU
Quote from: mrwayne on October 1 2012 on his web site
We expect to be finished by the end of the week - assuming all goes semi well (parts delivery)
and we will be ready for the Validation!
Quote from: mrwayne on March 29, 2014, 05:33:58 PM
p.s. two days run was for those of you who are stuck in the past......... We left you all behind.
Mark will be invited to our public release. He is a great skeptic.
Quote from: mrwayne on March 31, 2014, 03:44:50 PM
You are not wrong about me being over optimistic, you are not wrong about me being imperfect.
I love the new additions to the Wayne Travis bafflegab lexicon:  "Super Conservative Systems" and "Energy Reference Mapping".  These meaningless terms, much like the "Travis Effect" have been concocted to give a false pretense of scientific knowledge and legitimacy to the Wayne Travis investment fraud scheme.
MarkE
Quote from: camelherder49 on April 15, 2014, 05:38:53 PM
The acceleration due to gravity:  It's real!
Instructions at the bottom of the reservoir:  "When reservoir is empty, obtain more water.  Condensed atmospheric vapor formed from evaporated sea water is a good source."
