mondrasek
Quote from: TinselKoala on February 22, 2014, 08:24:38 AM
And your nested system is significantly different.... how?
The analysis I have shown, in effect, isolates the system being analyzed just as the red box did to yours.  It is similar to treating the enclosed system as a "black box."  Then we only need to concern ourselves with what crosses the barrier of that box.
The point of significant difference is this:  A correct analysis of your UTube system shows that the Work/Energy input=output (unity).  The results of the ZED system that I am analyzing show that input<>output (non unity).
1. You are confusing yourself with "Boyle's Law" pressure/volume calculations, because Travis and Red Sunset and Webby have all said that the air can be replaced with incompressible fluid. All chambers in your system should be filled with fluid that doesn't change in volume when it's under pressure.
All internal chambers have been replaced with an incompressible fluid.  There is the water (SG=1), and the air (SG=0) that is ASSUMED to be incompressible for this ideal case.  We can change those two fluids to real incompressible liquids of different specific gravity values if the assumption needs to be tested falsifiable.  But when you do the math you will see that the greater the difference in the SG of the two fluids used, the greater the output to input ratio once unity has been surpassed by proper ZED design.  Also, you can see that a compressible fluid such as air only causes a loss to the system.  So using two liquids will result in a higher performance, just so the difference in the SG of those fluids is > 1.
The outer chamber of the system is NOT filled with an incompressible fluid.  It is open to the atmosphere.  So an open system.  I find that interesting and a possible reason that Boyle's law may not apply?
1b. Air -- wet air -- is not an ideal gas and you will find that it deviates from strict Boyle-Charles law behaviour. How much? Enough to account for your numerical result? I don't know. Do you?
No air (or wet air) is used in the system under analysis.
2. You should be able to demonstrate some actual gain in something, somewhere, using just three layers. Travis has told us so!
The analysis of the 3-layer ZED does show that.  PinVin<PouVout.
3. What, exactly, is the real "output" of your system? Is it a lifted weight? If you are counting pressing against a stop as "output work", that's not kosher!
The output is being calculated as the Integral of Pout * Vout, ie. Work/Energy.  Pout is the average pressure of the ASSUMED linear declination of the maximum lift pressure (calculated from the buoyancy force at full charge applied to the surface area of the outer riser) as it falls to zero (where the system should be at neutral buoyancy after being allowed to rise due to the charge).
I have never calculated the real Vout.  Instead I have ASSUMED the system follows Boyle's law and would therefore have a Vout that can be calculated by the specified and calculated Integral of Pin, Vin, and the Integral of Pout.  Once that Vout is calculated I construct a model that has stroked to the height that would require and reevaluate.  If Boyle's law were true, then the system after applying this stroke value should be at neutral buoyancy.
It is not.
In the 2-layer model the system fails to satisfy Boyle's law by displaying PinVin>PoutVout (underunity).
In the 3-layer model the system fails to satisfy Boyle's law by displaying PinVin<PoutVout (overunity).
M.
QuoteAll internal chambers have been replaced with an incompressible fluid.  There is the water (SG=1), and the air (SG=0) that is ASSUMED to be incompressible for this ideal case.
So what are you doing mentioning Boyle's Law at all? Boyle's Law is the relationship between Pressure and Volume of compressible (ideal) gases. You are assuming incompressibility at the top, then complaining that your system doesn't follow the law of compressible gases?
QuoteI have never calculated the real Vout.  Instead I have ASSUMED the system follows Boyle's law...
Maybe that's your problem then, since incompressible fluids do not follow Boyle's Law of the pressure-volume relationship of ideal, compressible gases.
And work is only performed when forces act over distances. Pressing against a stop with some pressure is not work. Does your butt do work on the chair you are sitting in?
mondrasek
Quote from: TinselKoala on February 22, 2014, 10:23:05 AM
So you are saying that Boyle's law does not apply to a fluid once it changes state from a vapor/gas to a fluid?  I thought that once the fluid is incompressible then the volume cannot change.  And then Boyle's law of P1V1=P2V2 would reduce to Integral of P1 = Integral of P2.  Are you saying this is incorrect?
I'm not sure how this applies?  Work is not being calculated while pressing against a stop.  A non unity quantity of Energy is.
Quote from: mondrasek on February 22, 2014, 10:49:15 AM
Who is talking about phase changes here? Your device is filled completely with two incompressible fluids. No phase change happens. Boyle's Law does not apply to incompressible fluids!
QuoteI thought that once the fluid is incompressible then the volume cannot change.
That's right: The pressure applied to the fluid is _unrelated_ to the volume of the fluid, it does not affect the volume, and no amount of applied pressure can change the volume of an _incompressible_ fluid, and no energy can be stored by "compressing" or applying pressure to an incompressible fluid.
QuoteAnd then Boyle's law of P1V1=P2V2 would reduce to Integral of P1 = Integral of P2.  Are you saying this is incorrect?
How many pounds per gallon does a speed of 60 seconds per bushel represent?
I am saying that no pressure change will result in a volume change of an incompressible fluid, therefore Boyle's Law is irrelevant and inapplicable! So Boyle's Law reduces to P1V1 = P2V1 since volume cannot change in an incompressible fluid, and this relation is contradicted by experiment (pressures can certainly be different for the same volume of water, a nearly incompressible fluid) because Boyle's Law is not applicable to _incompressible fluids_ !! It is an IDEAL GAS LAW and ideal gases are ideally compressible ... that is what Boyle's Law tells you!
I'm not sure how this applies?  Work is not being calculated while pressing against a stop.  A non unity guantity of Energy is.
In a previous post you stated that the pressure against the stop caused by your calculated excess buoyancy represented a gain, I thought. And work and energy have the same units, the Joule in SI. If you are calculating Energy you are also calculating Work and vice versa.
mondrasek
Quote from: TinselKoala on February 22, 2014, 11:23:15 AM
Sorry if my previous explanation was not precise.  I did not mean to imply that any phase change occurs in the ZED system.  It does not.  I was only tring to explain that I thought Boyle's law would apply to liquids once they had changed phase from vapor to liquid.  If that is in error, I accept that and appreciate you pointing out my misunderstanding.
I'm sorry if I don't understand your point here.  I would appreciate if you can try another way to help me grasp it.  Seriously.  But I see no Energy being store in "compressing" anything in the process I am analyzing.
I know!  But the analysis appears to show that the ZED system would need to stroke (under pressure) more than would be required by inputting the same volume of charge liquid under the same pressures that an equivalent hydraulic system would.  And so I don't understand!
Now if using Boyle's law to calculate the energy input due to the charge volume being introduced is wrong, then the analysis is wrong.  Completely wrong.
Can you offer a correct method?
I tried to state that by the method I was using to calculate it appears there must be more energy after the system "power stroke" than is predicted by the falsification test.  So either the test is erroneous or there must be excess energy left in the system.
TK, thank you for engaging and helping me to work this out.  It is much appreciated.
M.
