MarkE
Quote from: mrwayne on March 02, 2014, 11:52:42 PM
Monderask - I hope you do not mind,
MarkE,
The Ideal Analysis gets the calcs in your math right. Well Done.
The  math simply shows the physics that has been known for over two millennia.  It is the same physics that proves you are selling lies for cash.
I will act as you were never told the states - for sake of time.
With you it is always acting.
So lets get your states set up, and in order.
Conditions
ZED A Sunk remaining head due to riser weight and any added weight - ZED A  will be the receiving ZED,
ZED B is at the end of delivering a load and in the raised position - and was not allowed to Bob up after the load was removed.
State one - Start with sunk - still head remaining - equal to the weight of the risers - and any additional load. (additional load is sometimes used to reduce time by reducing expansion and contraction during cycles)
p.s. Adding weight is counter intuitive - most people assume adding weight induces losses
Lesson to be learned - trying to achieve Ideal usage results in self determined conservative process.
The next state is post free flow - this is where the other ZED A and B have equalized between the stroked ZED and the sunk ZED. No riser movement in either ZED - only fluid and pressure.
Note: Free flow results in equalized pressure - but not equalized volume.
The next State is changing from Free flow too "precharge"
Full precharge is the end of the state between free flow and enough buoyancy to nuetralize the determined load and no riser movement either ZED.
The process to get to the full precharge state - two inputs are utilized :
One - the continued consumption of pressure from the ZED B - and the hydro assist.
The hydro assist adds enough pressure - that when combined with the exhuast from the other ZED - reaches load neutrality (buoyancy). This is full precharge for ZED A.
Note: ZED B will not sink until the stored head has dropped below nuetrality of the risers and any added weight.
The Hydro Assist continues to be combined with the Pressure from ZED B - the input cost is the differance between the sinking ZED pressure and the stroking pressure required.
The next state is the Production Stroke of ZED A. ZED A stroking and ZED B sunk is the first half of a Dual ZED cycle - the process repeats in the other direction - notice I did not say reverses.
To understand Stroke - you must determine both the proper load and the proper stroke.
The proper load is the lift safely available at the determined end of stroke.
Iterations are helpful..... I will give you a rule of thumb - Do not make the stroke longer than 1/11 the height of the ZED.
(another counter intuitive - short stroke is a more efficient process)
Use your baseline calculator already prepared to determine what the load is at that height - and that is a good load - presuming riser weight and any added weight has already been considered.
Unlike the states Mark described - the precharge and stroke is only released into the other ZED - not bobbed up or consumed as production.
The transfer of the precharge and Stroke is made mechanically more efficient as Webby described and posted two of our methods.
but you do not need to add those improvements to find the outcome.
Last notes - when the full precharge is reached - any additional volume input into the ZED A results in production - so once precharge is hit - no consumption of the previous pressure occurs - the ZED B hits bottom at the end of the production stroke on ZED A.
In simple observation - the true cost of stroking a half cycle is all of the stroking Pv ZED A, minus the sinking ZED B Pv, and then repeat for a full cycle.
A full cycle is a return of ZED A to "Sunk.
MarkE - if you do understand these States - you should be able to see how we transfer two sets of PV left and right - not consuming that value and truely reducing the total input cost.
Lastly - the Hydro Assist is the external input - which can be powered by the Production. When you determine the cost of the Hydro Assist versus the production - you will understand why I have been so patient.
Wayne
So many words you utter, so much attempt you make to distract with utter bull shit.  Nothing you have shown or can show will result in an energy gain from cyclically lifting and dropping weights.  The "Ideal ZED" as Mondrasek has laid it out is a less than useless machine that expends energy while doing no useful work.  It is an allegory for what investor funds in your sham companies do: No useful work.
mrwayne
Quote from: MarkE on March 03, 2014, 12:03:13 AM
The  math simply shows the physics that has been known for over two millennia.  It is the same physics that proves you are selling lies for cash.With you it is always acting.So many words you utter, so much attempt you make to distract with utter bull shit.  Nothing you have shown or can show will result in an energy gain from cyclically lifting and dropping weights.  The "Ideal ZED" as Mondrasek has laid it out is a less than useless machine that expends energy while doing no useful work.  It is an allegory for what investor funds in your sham companies do: No useful work.
So do you give up?  it is simple from here.
mrwayne
Quote from: TinselKoala on March 03, 2014, 12:01:29 AM
Is there really any need to say more?
"Lastly - the Hydro Assist can be a external input - or powered by the Production leaving excess. When you determine the cost of the Hydro Assist versus the production - you will understand why I have been so patient."
TK, Did you think that thru....
mrwayne
Everything you need to prove our claim of Net Energy
Conditions
In simple observation - the true cost of a stroke half cycle is all of the Hydro assist - which is also the stroking Pv ZED A, minus the sinking ZED B Pv, and then repeat for a full cycle.
The production cycle is both ZEDS having produced once and combined.
MarkE - if you do understand these States - you should be able to see how we transfer two sets of PV left and right - not consuming that value and truely reducing the total input cost - the remaining input cost is the hydro assist.
Just As Webby pointed out that Mark D stated in his own video of our running system.
http://www.youtube.com/watch?v=q-0TITC4Wrc
The Excess or Net per half cycle is no more than the value between the Pv sinking and the production - Not magical - but free.
Wayne
So we have been waiting YEARS for that verbage, Wayne?  Your precharge this and assist that would make any hydraulic engineer have a good belly laugh.  How about an energy audit for each stage of your alleged system?   You know, Joules, energy states, stuff like that?
Your teaser game where people have to figure it out with "pointers" from you is truly sick.  Why do you play this game Wayne?  What is your motivation?
What you really need is a big honking compressed air tank.  I am convinced that's what powered the groaning bellows monster that you showed on video two years ago.
When are you going to deliver a working system, Wayne?  What will the power output be, and what form will it take?  Where will it go?
