0 Members and 35 Guests are viewing this topic.
mrwayne
Quote from: MarkE on March 06, 2014, 01:34:26 AM
I have advised you that you are behaving very poorly and that reflects badly on you.
..really.. Omgosh
mrwayne
Pencils ready!
Try using this process - and you will see that we do not release the "spring" as you describe.
I will post it again.
So lets get your states set up, and in order.
Conditions   At least three layers Each ZED:
ZED A Sunk remaining head due to riser weight and any added weight - ZED A  will be the receiving ZED,
ZED B is at the end of delivering a load and in the raised position - and was not allowed to Bob up after the load was removed.
State one - Start with sunk - still head remaining - equal to the weight of the risers - and any additional load. (additional load is sometimes used to reduce time by reducing expansion and contraction during cycles)
p.s. Adding weight is counter intuitive - most people assume adding weight induces losses
Lesson to be learned - trying to achieve Ideal usage results in self determined conservative process.
The next state is post free flow - this is where the other ZED A and B have equalized between the stroked ZED and the sunk ZED. No riser movement in either ZED - only fluid and pressure.
Note: Free flow results in equalized pressure - but not equalized volume.
The next State is changing from Free flow too "precharge"
Full precharge is the end of the state between free flow and enough buoyancy to nuetralize the determined load and no riser movement either ZED.
The process to get to the full precharge state - two inputs are utilized :
One - the continued consumption of pressure from the ZED B - and the hydro assist.
The hydro assist adds enough pressure - that when combined with the exhuast from the other ZED - reaches load neutrality (buoyancy). This is full precharge for ZED A.
Note: ZED B will not sink until the stored head has dropped below nuetrality of the risers and any added weight.
The Hydro Assist continues to be combined with the Pressure from ZED B - the input cost is the differance between the sinking ZED pressure and the stroking pressure required.
The next state is the Production Stroke of ZED A. ZED A stroking and ZED B sunk is the first half of a Dual ZED cycle - the process repeats in the other direction - notice I did not say reverses.
To understand Stroke - you must determine both the proper load and the proper stroke.
The proper load is the lift safely available at the determined end of stroke.
Iterations are helpful..... I will give you a rule of thumb - Do not make the stroke longer than 1/11 the height of the ZED.
(another counter intuitive - short stroke is a more efficient process)
Use your baseline calculator already prepared to determine what the load is at that height - and that is a good load - presuming riser weight and any added weight has already been considered.
Unlike the states Mark described - the precharge and stroke is only released into the other ZED - not bobbed up or consumed as production.
The transfer of the precharge and Stroke is made mechanically more efficient as Webby described and posted two of our methods.
but you do not need to add those improvements to find the outcome.
Last notes - when the full precharge is reached - any additional volume input into the ZED A results in production - so once precharge is hit - no consumption of the previous pressure occurs - the ZED B hits bottom at the end of the production stroke on ZED A.
In simple observation - the true cost of a stroke half cycle is all of the Hydro assist - which is also the stroking Pv ZED A, minus the sinking ZED B Pv, and then repeat for a full cycle.
The production cycle is both ZEDS having produced once and combined.
A full cycle is a return of ZED A to "Sunk.
Lastly - the Hydro Assist can be a external input - or powered by the Production leaving excess. When you determine the cost of the Hydro Assist versus the production - you will understand why I have been so patient.
The Excess or Net per half cycle is no more than the value between the Pv sinking and the production - Not magical - but free.
MarkE
Quote from: mrwayne on March 06, 2014, 05:22:02 AM
..really.. Omgosh
Well good morning Wayne.  What do you think about Mondrasek's "ideal ZED" now?  Do you have any new insights into how to make his short travel, linear spring emulating device into an over unity machine?  Can you help out showing where gravity can be modified here to become non-conservative?
And why is  it that determining the values in this machine is possible as demonstrated without resorting to any iterative calculations?
MarkE
Quote from: mrwayne on March 06, 2014, 05:29:26 AM
Pencils ready!
Useless wall of text.
And why is it useless?  It is useless because nowhere in it does it describe anything that can or will change the behavior of even Mondrasek's idealized device from that of a linear spring to something that can create energy.  If something is passive, it does not create energy.  Adding more instances of passive devices does not introduce anything that produces energy.  But it is nice to see that you are intent on evidencing your scienter.
MarkE
Step right up and get 10 better than "ideal ZED" devices for less than $12.00!  These devices require no precharge, have no set-up losses, occupy a tiny fraction of the volume of the "ideal ZED", can store more than 10 times more accsessible energy than the "ideal ZED", don't leak, work in any orientation, don't lose fluid to evaporation, and don't corrode themselves with water!  What they have is the same force versus distance constant as the "ideal ZED".  Instead of a fully extended envelope of greater than 69.5mm H x 46mm Dia, these babies are less than 15mm long by 3mm diameter.  IOW they fit in less than 1/1000th the volume of the "ideal ZED" while exactly matching the "ideal ZED" transfer function, without any of the complexity or headaches.  That's right:  They have more than 10,000 times the accessible volumetric energy density as the "ideal ZED".  And did someone mention cycle rate?  The self resonant frequency of these springs is in the thousands of cycles per second.  How fast can a ZED cycle?  All that and they cost less than $1.20 each when you buy 10 at a time and save!
http://www.amazon.com/Compression-Spring-Stainless-Compressed-Capacity/dp/tech-data/B005S4HDZ8
Compression Spring, Stainless Steel, Metric, 2.82 mm OD, 0.32 mm Wire Size, 6.1 mm Compressed Length, 14.2 mm Free Length, 3.91 N Load Capacity, 0.48 N/mm Spring Rate (Pack of 10) Price:    $11.73
